Question about Coleman Air Tools & Compressors
What is the number on the capacitor for this 27 gallon coleman powermate air compressor? This one uses oil.
2 Suggested Answers
  • 1388 Answers
SOURCE: coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Posted on Jan 10, 2009
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need starting and running capacitors for 8-182852-nu century motor on coleman 6hp compressor. Thanks!
get the micro farad and volts of your capacitors, then bring it to the electrical supplies
Aug 23, 2010 | Coleman Powermate 60 Gallon Air Compressor
Compressor pressure only to 60 lb psi and no more
not sure but it sounds like the piston ring is worn out or you might have a bad valve.
p.s. its not your typical valve like in a car.
is it a wet compressor, check the oil.
Feb 21, 2010 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
I would like to find info on the capacitors for my 27gal powermate air compressor
? should be printed on them careful as they bite when discharging if you need replacement try mastertoolrepair.com they have them
not sure on best way to discharge them hope this helps
Jan 18, 2009 | Coleman Powermate 27 Gallon Air Compressor
Need replacement brushes for Coleman Air Comp L0552709
you can try at mastertoolrepair.com they have parts just have to see if your model is in there system
Jan 14, 2009 | Coleman Powermate 27 Gallon Air Compressor
Air Tools & Compressors Logo
80 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
