Question about Refrigerators
The freezer fan is running with noise;need the access to him
  • Refrigerators Master
  • 5,323 Answers
COULD BE DUE TO AN ICE BUILD UP IN FREEZER WHICH ITSELF COULD BE DUE TO DEFROST PROBLEM? OR THE FAN HAS A BROKEN DAMAGED PROPLELLER
Posted on Apr 07, 2015
Master-Bilt commercial freezer Bearings
If you can access the condenser fan, jam it with a screwdriver handle so it can't revolve. switch on and see if the noise still appears. If not, change the fan motor. If so, change the compressor.. Don't let the compressor run without the fan operating more than to test for the noise.
Apr 25, 2014 | Freezers
I have a Kenmore Bottom freezer side by side model 795-7130. The evaporator fan is making noise that stops when I open the door. How do I access that fan please? I can't find a repair manual fo
it is inside the freezer, remove the drawer, then the rails that hold the drawer. this can be an intimidating job. then the fan cover at the top of evap cover needs to come off. then you can remove the evaporator cover which may have screws or may just pull off. if it gets too big call for service
Jan 08, 2012 | Kenmore Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
My refrigerator's inner fan was making weird noises. After some time I poked it and then it stopped moving. The fan is now unable to turn. What should I do?
Two things could be wrong. Motor bad or frozen up with ice.The noise could have been
from frost building up and hitting the fan.If this is the case you need to defrost. Even self
defrost models do this some times..Empty freezer and run a hair blower (dryer) to put heat
in the compartment. this could take a while to do. over night...So run blower for a while to heat up the freezer then shut it off, close door .let sit It takes time for the heat to get to the ice.
if the motor is bad you will have to take inside cover off the access the motor
Oct 13, 2010 | Frigidaire Freezer Refrigeration White...
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
I am getting a loud noise from the freezer compartment of my older, Kenmore refrigerator.
The noise may be a failing evaporator fan, but it's more likely to be ice that has accumulated around the fan and the fan blades are hitting it.
You will need to access the fan behind the cover in the freezer to check this out. The unit should be off so the blades aren't moving when you check.
Mar 19, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
