Question about Danby DBC039A1BDB 124.00 Beverage cans Beverage Center
I have no power what so ever.. Is there a trip switch or something of that nature?
  • 4 Answers
If no power to the unit, you need to check if its plugged in for one keep it simple. if yes do yo have power at the outlet easy to check with a multimeter. you can also just check the breakers in your electrical panel.. if that doesn't do it you may want to call your local refrigeration a/c tech for further assistance but check the above first
Posted on Apr 04, 2015
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Sta-rite heater is about a year old. It worked well up until a week ago. It now trips the gfi breaker. I swapped out the breaker and it trips that too. If I disconnect the exhaust fan, the heater powe
Something in the electrical system supplied by the GFI breaker has a ground fault. The current to ground required to trip a GFI is very little such that dampness on any electrical connection can trip it. This is especially true with motors that have a lot of fine wires in the windings and are open to allow cooling.
Hard water and pool chemicals all are worse than condensation from the air because of their ionic nature.
If the same GFI powers the pump it is what I would suspect first. Your question got cut off before the result of the fan disconnect which if disconnected didn't trip the GFI, is probably the problem. But you should open whatever you can access containing electrical components and make sure everything is dry
Feb 07, 2015 | Sta Rite Pool & Spa
Dead after power outage
The breaker may have failed electrically while continuing to function mechanically. It may be necessary to replace the breaker, something GE should have been able to tell you without referring vaguely to "an act of nature" which it wasn't.
Feb 26, 2014 | GE Dishwashers
Trips safety switch
Might be best to call the manufacturer or a licensed repaire to avoid voiding your warranty?
Jan 09, 2014 | Washing Machines
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Oct 20, 2013 | Rowenta DG-980 Iron
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
My Jandy Pol heater is giving me an error message of Hi Lim SW which I believe means that it has something to do with the High Voltage somethihg or other. Can you please help me?
Thank you for posting your question here on Fixya.com.
Hi limit switched are embedded in the header and trip when the water temperature is too high. Most of the time the cause is either a faulty sensor or poor flow thru the heater causing the exchanger to overheat. If you have a bypass plumbed into the water lines at the heater close it and see if the problem goes away. If not, you'll need to check the limit switches to see if they are faulty or if a condition exists causing them to trip.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
Danby DBC039A1BDB 124.00 Beverage cans Beverage Center Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
