Question about Cell Phones
I've tried over and over trying to find how to install my sim card into a jiake v5 I've had the phone since Dec and have yet to be able to use it please anyone can you help me???
  • Cell Phones Master
  • 4,095 Answers
What have you tried so far ?
Have you taken the back off the phone and looked under the battery ?
Posted on Apr 04, 2015
  • 70 Answers
SOURCE: N95 china mobile sim card problem
hte thing is...ur phone is handset bundled offer phone..so til the validity ends on ur new sim card..the phone is designed to detect only new sim..so ucant change til validity ends...or u may approach any private local mobile repair shop..i wont cost u much..
ne other prob's do tell me..N plz plz do rate me
cya
Posted on Apr 24, 2008
  • 94 Answers
SOURCE: offline
try open ur handset and make the pcb warm with ur hairdryer and fix it again i think it is due 2 moisture and it should work as its not picking simcard.try it and reply me with results.
Posted on Jul 18, 2008
SOURCE: How do I transfer the contacts from my SIM to the phone?
you can download the "EASY GPRS" or "EASY STUDIO" software from thefollowing site which supports almost all samsung mobile phones toconnect to the pc , transfering files and etc ...
you can download the software from this below given site:
http://www.samsung.com/us/support/download/supportDown.do?group=mobilephones&type=mobilephones&subtype=att&model_nm=SGH-D807&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=01010100&disp_nm=SGH-d807
the details on how to do it is available in this below given site
http://support.t-mobile.com/knowbase/root/public/tm21053.htm
thank you
rate my solution
Posted on Sep 11, 2008
SOURCE: i can't get my sim card out of my motorizr v3
try using an eraser head to slide the sim card out
Posted on Sep 21, 2008
  • 928 Answers
SOURCE: my sim card doesnt work in my sciphone i68+
I see that this had been a while. The reason that your Sim cad doesn't work could be various: 1. Make sure that your phone is quad band, if it's a tri band then make sure that ATT works in 1900mhz. If it works only in 850 and your i68+ is a tri band, (which is not suppose to) then it will never work. As far as I know all i68+ original are quad band, some fakes i68+ are sold as quad band but are actually tri-band. 2. If you ATT sim card is a 3g card, it won't work either. These phones are not yet equip to work with 3g. I hope this clear up at least a little of your doubt with the Sciphone.
Posted on Sep 17, 2009
How to install a sim card
The Barrage has no SIM card. Contact Verizon with the DEC MEID or ESN or HEX MEID to activate your phone.
Mark
Motorola Support
Jul 01, 2015 | Motorola Mobility Barrage Cell Phone
Insert correct sim card
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jul 29, 2012 | Sony Ericsson Walkman W810i Cellular Phone
How do i insert sim card into Apple I Phone
On the right hand side of your mobile about half way down you will see the sim card tray - you should've got a little metal tool with the phone when you had it to release this - if not, use the end of a paperclip and push it in the hole - the sim card try will pop out and you put the sim card in there and push the tray back in
May 08, 2012 | Apple iPhone 4S
My blackberry keeps rejecting my sim card :'(
I have the same problem with my curve 9360. It reject the sim card, but it was wordkinh all right:
Dec 13, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
Will not accept other sim card network for my nokia 6020 & 6300
one reason might be is that , your phone might be network locked and hence it is rejecting other SIM, If that is the case try unlocking your phone to use other networks, http://www.theunlockarena.com/ will help you with the process
Jul 23, 2011 | Nokia 6300 Cellular Phone
Update my phone now its writing insert correct sim card
Hi there! It's possible that your SIM card has become loose or has moved. Take the back off your phone and pull the battery out. Under your battery you'll see the SIM card somewhere (unless this is an iPhone, in which case you need to poke a little hole at the top of the phone with a paper clip to get at the SIM card). Pull the SIM card out and then reinsert it. This can "reseat" the SIM card and fix problems like this.
If you've tried to unlock your phone and it went poorly, then you will need to go to your carrier to get this problem fixed.
Alex
Jun 01, 2011 | Computers & Internet
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
Mar 07, 2009 | Motorola Mobility ic602 Cellular Phone
Subsidy passcode
You will need to try online at unlockitnow.com or mobile2mobile.net or take the phone to a mobile service center to have it unlock there.
Nov 25, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
