Question about 1A Auto Parts 1996 Chevy Cavalier Z24 GM Style Black Lug Nut Cap Set of 5
Steps on taking the cover off my 96 chevy cavalier without breaking it
The dome light wont go off so i want to take bulbs out but cant figure out hoe to take the cover off
2004 chevy cavalier dome light not working
Check bulb for continuity and also check the position of switch for the dome light.
Aug 26, 2017 | Cars & Trucks
2003 chevy cavlier 2.2 liter clicks but want start. No dashlights or radio. Dome light is on.
Possible dead battery? Dome light takes little electricity, so it's not a good indicator. Other things include bad solenoid,starter, ignition switch.
Dec 21, 2014 | PIAA 2003 Chevy Cavalier - All Cavalier...
How do i install a 1994 chevy caviler dome light
Remove the cover with flat tip screwdriver and remove old bulb and replace should snap out and in
Oct 20, 2014 | 1994 Chevrolet Cavalier
Where can i find a dome wiring diagram for a 1998 chevy cavalier ?
Do your dash lights work? Check the dash light switch to see if it rotates to control the dome light, it may be turned off completely or the dome light ground wire may be loose. If not the wiring will run from the back of the fuse block through the body post to the dome light Good Luck
Jul 27, 2014 | 1998 Chevrolet Cavalier
96 dodge ram 1500 dash lights wont come on unless I have my dome light on.
u may hav to remove bulb on dome-its not hard---the wiring is old or thers some module issue thats gonna take $$ n time
Oct 15, 2013 | 1996 Dodge Ram 1500 Club Cab
How to change dome light in a 2006 Lincoln Navigator?
There should be a plastic lens cover with clips,carefully wiggle lens off without breaking clips and remove bad bulb replace with new one and reinstall cover,but be gentle when taking lens/ dome light cover off,you don't want to break the clips that hold the cover on,I've replaced these bulbs and covers on every car I've owned almost 20 to be exact.
Mar 16, 2013 | Vehicle Parts & Accessories
My dome light stopped working. I think the bulb may be burned out. How do I replace it?
the dome light cover just pops off by prying with a screwdriver..this will expose the bulb and you can probably figure it out from there... sometimes the bulbs unscrew out and sometimes they pop out also
Mar 25, 2011 | Chevrolet Malibu Cars & Trucks
Have a 94 cavalier wagon and want to replace headliner. problem is i cant figure out how to get the dome light housings off. there are no screws visable. might be rivited?
did u pop the cover off the dome light?..screws are usually under the cover, where u would access to change the light bulb
Mar 13, 2011 | 1994 Chevrolet Cavalier
I need to take off the cover to the dome light in my 2005 subaru outback wagon. how does the cover come off so i can change the bulb? i didnt wanna try pulling it off and break it.
The bulb in our 2005 Outback dome light has been replaced twice---I found the best way to remove the cover is with a dime.
Jan 03, 2011 | 2005 Subaru Outback
1A Auto Parts 1996 Chevy Cavalier Z24 GM Style Black Lug Nut Cap Set of 5 Logo
21 people viewed this question
Top 1A Auto Parts Tools & Hardware - Others Experts
Pete Bruk
Lawrence Oravetz
William Alequin
Are you a 1A Auto Parts Tool and Hardware - Other Expert? Answer questions, earn points and help others
