Question about Proscan PLDED3273A 32" LED 720p HDTV with 60Hz Refresh Rate & 3 HDMI
What will make picture go black sound works - Proscan PLDED3273A 32" LED 720p HDTV with 60Hz Refresh Rate & 3 HDMI
What would cause a flat screen tv to have sound but no picture
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from ...I have sound no picture it would take a few minutes waiting before it would come back on . ... and I think I may have causedthis because it's been in for 2 days straight ... ken you helpe samung lcd tv no sound screen is black sound works ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... up to the screen, you have to look carefully but if youcan make out the ...
Repair A TV With Sound But No Picture - YouTube
? 2:30
https://www.youtube.com/watch?v=MQj2t4nNVYc
Sep 18, 2012 - Uploaded by MonkeySee
Jan 11, 2016 | Televison & Video
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Plasma has no picture but sound works???
If the set was struck even a moderate blow anywhere near the screen you may have a bad plasma display panel---the diffused picture sounds like that.
Sep 01, 2012 | Pioneer PureVision PDP-5040HD 50 in....
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
Sound , but no picture
TV has sound but no picture. It would work after turning on and off a time or two. Now all i get is sound and a black screen.
Feb 13, 2008 | Mitsubishi VS-5043 50" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Proscan PLDED3273A 32" LED 720p HDTV with 60Hz Refresh Rate & 3 HDMI Logo
274 people viewed this question
Top Proscan Computers & Internet Experts
David Payne
David Payne
 Mikey
Mikey
Are you a Proscan Computer and Internet Expert? Answer questions, earn points and help others
