Question about Frigidaire Freezers
Frigidaire upright commercial freezer started a LOUD buzz and the second light was on at the bottom front..turned off..then back on one hour later,.still loud buzz,..any idea what s wrong ?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The green light should be a normal running light and the other one, either yellow or red(ish) should be a high temp alarm. Check the contents to make sure they are still reasonablly frozen and if not start finding the cause....Is the condensor fan motor running correctly? Is the condensor coil clean and free from dirt/lint/fuzz which serves to restrict the transfer of heat? Is there an excessive accumulation of ice build up indicating possibly a problem with the automatic defrost cycle?
Posted on Apr 08, 2015
Started making a loud buzzing noise. Have tried unplugging it and turning it off and on.
Good Morning Denise, thank you for your inquiry!
From the information you have provided your Frigidaire freezer is making a buzzing noise and it will not stop. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If the buzzing continues I would be happy to research your freezer further, in order to do so I would need your model number. You can locate the serial tag (which lists your model number) on the inside wall. Once I have that information I would be happy to help you further. -Matt
Mar 08, 2016 | Frigidaire Freezers
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
232 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
