Question about Home
I bought a large MS cutting board two days ago. I haven't used it yet and it's already warped! I don't have the plastic it was wrapped in or the barcode but I have the receipt. Can I get a refund?
4 Suggested Answers
  • 1564 Answers
SOURCE: ,We use a lot of large square bales to bed cattle
how about a carpet hook type knife?
Posted on Sep 05, 2012
SOURCE: New dishwasher already wet inside when opened for first time! Is it ok?
My counter-top dishwasher Danby DDW611WLED delivered was wet inside, a strong humid air came out from inside when I opened the door at the first time, I suspected it a returned item but after reading several forums, it looks like that it's normal to have some water inside since the manufacturer makes some tests before ship out. I guess in the normal condition you may not see it wet but when it's been put up-side-down or put on its side, some test water left inside at the bottom may come out and leak to everywhere. The fact is my UPS delivery guy rolled the dishwasher box from his car over the stairway up to my door instead of carrying straight up. If it's true then it's stupid that the manufacturers don't mention this situation could happen in their manual or big notice label on the front door of the machine. Everyone sees this kind of situation can suspect it as a used item, frustrated and then return their products. Anyway, you can call the customer service and let them confirm to you if it's normal or not.
Posted on Jul 04, 2013
  • 11 Answers
SOURCE: Cancel and refund receipt CALL-U0804141652-40SAW. This is a duplicate program or one already installed on my computer. Cannot afford athis program.
Call the place your purchased it from they should
be able to tell u
Posted on Apr 16, 2014
Tip
Some Creative Ideas for Gift Wrapping
  • You don't have to rely on boring shop bought gift wrapping paper. If you are looking for something alternative, take a look at the ideas below.
  • If you have a printer at home you can use your computer to set up a personalized pattern ie a name and then print the paper with the recipient's name all over it.
  • Use spare bits of fabric to wrap up gifts. You can tie it with ribbon to complete the effect.
  • Even cereal boxes make great boxes for gifts. cut them up and glue or stapel them into shape and then cover with paper or fabric.
  • Use cheap plain paper but cut out decorative pictures from old greeting cards to add vibrancy and color.
  • Use plain white printing paper but tie it up with a fancy ribbon. It looks great!!
on Sep 22, 2013 | Event Planning & Celebration
Tip
Teflon Tape .. What else can I use?
I just found a good alternative to Teflon Tape.. A good old plastic grocery bag, Yep in a pinch this works great, and may be just a permanent as the store bought tape is. Cut you a strip as long as you would use from a tape roll and wrap the pipe or what have you with the plastic bag, your back in business.
on May 25, 2010 | Plumbing
Msi n1996 motherboard driver
This is your lucky day. I have that very board in my hands and was able to find the downloads on the MSI website. Cut and paste this link to get to the driver downloads. Pick and choose what you need. Don't let the MS-7388 bother you. You can click on the photo and see both MS-7388 and N1996 on the board.
http://msi.com/product/mb/K9A2-CF.html#/?div=Driver&os=All
Dec 24, 2011 | Computers & Internet
Panasonic TX-56P800H Bought years ago but has had very limited use. Switched on the other day and then cut out with small red light near power/ac button on unit keeps flashing and remote will not...
I think that the cause of the problem is that your power supply is already weak, try to check the main power supply but be sure to unplug your tv. try to observe if their is a leaky capacitor the one that has a wet mark in the bottom the wet mark is the oil of the capacitor try to replace it specially the 50 volts 10microfarad.
Jul 03, 2011 | Televison & Video
When brakes are depressed for stopping, Steering wheel vibrates violently, what could be causing this?
Front brake rotor, there wrap which happen from one day to the next, if you just had a brake job done need to take it back, rotor's were not cut right. make sure they check for thickness of rotor's before cutting, if to thin will work for a while and then start to do it again, good luck.
May 21, 2010 | 2006 Chevrolet HHR
Hi,need to install 6x9 spreakers to my bmw e36 coupe rear shelf but see no other way to do it unless cut some metal off.May be there are ways to do it without any modifications?
You can make some plates from mdf or the like to "lift" the 6x9's up (can also be bought, but I can't remember were I bought mine from, was a while ago). just cut some mdf to take the speaker and cut about 1" around, paint or cover with material and screw through to the shelf.
Jul 05, 2009 | JBL GTO937 Car Speaker
Hello , I just bought an 80 gb hdd. I installed it to a MS 6119 ver 1.2 bx2 board, but its not picking in bios. But with Winxp it picks up when I start up the pc with xp cd, it picks up the 80 gb hard disk...
I am ArmyMason and I believe the issue is the hard drive is too large for the system you have. That board is old and back in the day they didnt support large hard drives. You could try using a boot disk and partition the hard drive into 20 GB drives and see if that works.
http://global.msi.com.tw/index.php?func=proddesc&prod_no=332&maincat_no=1
Link to specs.
Thanks ArmyMason
Feb 24, 2009 | Computers & Internet
CANNOT OPEN DLL FILES
If you just want to see what the inside of a dll file looks like, you can use a text file viewer. Don't use an editor, because any change at all to the file will corrupt it (including word wrap, for instance). You can do a web search and find hundreds, but something like Large Text File Viewer http://www.topshareware.com/Large-Text-File-Viewer-download-11000.htm would do the trick.
Dec 23, 2008 | Computers & Internet
Projected image is too large for screen
Good Day Brian;
The warped, too large picture is the same problem, the TV has a convergence problem. ln today's electronics the first thing that should be done on any electronic device is to, reset, unplug TV from the a/c outlet for at least 4-5 minutes then plug back in. If no fix; Your TV has a circuit problem. RCA has three common problems that could cause this condition; the most common is a fuse near the fly-back, IH-VT, the convergence power board or the signal board.
Always, call a factory authorized service dealer if you are not familiar with repairing electronic equipment that contain HIGH VOLTAGE, just for your own safety.
Good Luck, Big Irish.
Jun 21, 2008 | RCA Televison & Video
Home Logo
536 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
