Question about Konica Minolta Magicolor 5650EN Color Laser Printer
"Service call0300 Polygon Mot" - Konica Minolta Magicolor 5650EN Color Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
Polygon motor is the motor located inside the print head where the LASER is at the motor is what moves the LASER beam across the drum when placing the image on the drum. SO you might have a bad print head because the motor and LASER come as one. And no you can not replace the motor separately.
Posted on May 18, 2015
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
Problem mot pass bios toshiba satellite u200
Emporte l'ordinateur ou envoie-le au centre de service local de Toshiba pour effacer le mot de passe. Il est possible que tu doives prouver que l'ordinateur t'appartient. Possible aussi que tu doives payer pour le service si ton ordinateur n'est plus sous garantie.
Mar 29, 2014 | Computers & Internet
Service call 0300 polygon mot
Replace the print head which houses the LASER
Feb 01, 2014 | Konica Minolta PagePro 4650EN - Printer -...
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
I have a toshiba photocopiar and this copiar problem disply of error L 6 10 code pl resolved/ solution problem
The polygon motor does not rotate. The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock signal is detected for 1sec during rotation of the
polygon motor.
Cause:
Improper connection or disconnection of the polygon motor and the harness.
MCU PWB abnormality
Check and remedy:
operations.
harness/connector.
Jun 02, 2011 | Toshiba e-Studio 161 Copier Copier
C4154 Trouble code... what is it?
C4154 means that the Black Polygon Mirror Motor is not rotating or spinning as it should.
You can try turning the machine off and on to reset the code and see if it comes back. If so then you will need a service tech to come out and service it. The Polygon Mirrir Motor is a spinning mirror that the laser is bounced off of and is used to write the image to the drum unit.
Here is the info direct from the service manual:
C4154:The polygon motor fails to turn stably even
after the lapse of a given period of time after
activating the polygon motor.
• Motor lock signal detects HIGH for a given
period time consecutively during the polygon
motor is rotating
Good Luck and Thank You for using Fixya.
Feb 02, 2011 | Konica Minolta Bizhub c203 Copier
RICOH SPC430DN error sc202
sc202 is a polygon mirror motor. The most likely problem is that the motor has gone bad, and it will need to be replaced. Occasionally this error is caused by a loose or disconnected cable, but it is usually a bad mirror motor. You should contact your local service technician for replacement of the polygon mirror motor.
Nov 18, 2010 | Ricoh CL4000DN Laser Printer
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Konica Minolta Magicolor 5650EN Color Laser Printer Logo
192 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
