Question about Lifespan TR1000-HRC Folding Treadmill
Are there fuses on the lifespan tr1000 hrc treadmill
Does not turn on
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Treadmill wont start
see the video and fix it .God bless you
Jul 14, 2013 | Exercise & Fitness
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
I have a LifeSpan TR1000-SL that stopped running. We are getting an E1 error code and do not know what this means or how to fix it. Ayy help you could provide would be much appreciated. Thanks in...
abrupt shutdown of the belt as the motor control detect a sharp increase in drive
current and inmediately stop driving belt.Some situation as jamming the belt may cause this error.Without such abuse should be a cause for extreme care and analysis for some Tech.
2 reason:
1) Motor drive; possible faulty(Test)
2) motor control board : possible faulty(Test)
Aug 09, 2011 | RTO Lifespan Fitness TR1000 Sl Treadmill
Lifespan tr1000 sl, runs for awhile then numbers start to flicker then motor slows down, speeds up, slows down and stops, then beeps and shows error code e-1
2 reason:
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Aug 04, 2011 | RTO Lifespan Fitness TR1000 Sl Treadmill
I have a LifeSpan TR1000-TV treadmill. After 30 to 45 minutes walking on it at a 3.8 mph pace, it suddenly stops. After a few seconds the message "Err. 1" comes on the display. If I shut it off at the...
Hi, same thing here when i had the problem. I called LifeSpan and was also asked to lubricate the belt and since then i have not experienced the problem again.. It seems you have to call LifeSpan again and ask of the technician to come down and check it out since the only solution to the problem is not working and helping....
Take care
Jul 21, 2010 | Lifespan Fitness TR 1000HRC Treadmill
My treadmill is showing an E1 error code, what does this mean?
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 07, 2010 | RTO Lifespan TR1000TV - TR1000 With A TV...
Will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Apr 30, 2010 | RTO Lifespan Fitness Tr 2000 Hrc Treadmill
I can't get it to start I have no manual. The lights on the display work.
Get In Touch with: PCE Fitness @ (877) 654-3837 x114 they should be able to help you. They are in Salt Lake City Utah
Apr 15, 2010 | RTO Lifespan Fitness TR1000 Sl Treadmill
Lifespan TR1000-HRC Folding Treadmill Logo
66 people viewed this question
Top Lifespan Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Mike
Mike
Electro Med Services...
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
