Question about Oster Microwave Ovens
Have model#OGS31102 it stopped heating any possible solutions only paid $70.00 at k-mart all service ctrs in pa. far from me,very handy person
    New Friend:
  • 8 Answers
Heating element could have gone out even with it new I'd take it back to store
Posted on Apr 03, 2015
    Top Expert:
  • Oster Master
  • 48,482 Answers
70.00 it will cost far more to have it repaired. throw away and get another one
It won't heat things, Model #OGS31102
test this components and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Oct 24, 2013 | Oster Microwave Ovens
My panasonic will run for about six seconds and stops, and smells like burning wires and it shows a message "SENSOR RE-HEAT PRESS START"
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor. But I don't think that's the issue here.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Nov 30, 2012 | Microwave Ovens
Micro is turning on ok and working but not heating up,what would cause that? light is on ok and plate is turning, just not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Jan 28, 2010 | Sanyo EM-G2585W Microwave Oven
Keypad stopped working.
First, be sure the child lock is off. It may have an "L" or the word "LOCKED" showing in the display.
You can unlock it by pressing and holding the CLEAR pad for 5 seconds or so. Your model may use a different key, maybe the "0" (zero) key.
If that doesn't fix it, since it's still under warranty you should grab your sales receipt and your owner's manual and call vendor's(make of your oven) customer service to find the nearest authorized servicer.
There may be some foreign substance on the circuit board or inside the layers of the keypad. Most commonly this is due to spray cleaner being sprayed directly onto the keypad.
Cleaner should be always sprayed on a soft cloth first, then use the cloth to wipe the keypad clean.
Always use alcohol-based cleaner on microwaves, never ammonia-based cleaner, which can crack and/or warp the plastic.
If this is what has happened, it would not be covered under warranty, and it may or may not be repairable.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel.
If so, it is possible to dry it out with an air compressor or heat.
Otherwise please contact any nearest repairman.
Jun 15, 2009 | Microwave Ovens
Sharp Microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jul 24, 2008 | Sharp R-630D Microwave Oven
Cut out during heating
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Jul 16, 2007 | Belling BIM60 Microwave Oven
GE MICROWARE WON,T HEAT UP
Likely problem: Blown magnetron. On microwaves, this can generally go dead, usually with a popping sound. Solution: A: Call an appliance repairman to replace the magnetron in the device, or B: buy a new microwave. Depending on how much you paid for it, you might be getting a better deal on either end.
Jun 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Power is on, but won't cook
First, be sure the child lock is off. It may have an "L" or the word "LOCKED" showing in the display. You can unlock it by pressing and holding the CLEAR pad for 5 seconds or so. Your model may use a different key, maybe the "0" (zero) key. If that doesn't fix it, since it's still under warranty you should grab your sales receipt and your owner's manual and call LG / Goldstar customer service at 1-800-243-0000 to find the nearest authorized servicer. There may be some foreign substance on the circuit board or inside the layers of the keypad. Most commonly this is due to spray cleaner being sprayed directly onto the keypad. Cleaner should be always sprayed on a soft cloth first, then use the cloth to wipe the keypad clean. Always use alcohol-based cleaner on microwaves, never ammonia-based cleaner, which can crack and/or warp the plastic. If this is what has happened, it would not be covered under warranty, and it may or may not be repairable. A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out with an air compressor or heat, but often that does not work.
Nov 10, 2006 | Goldstar MV-1615 Microwave Oven
My microwave runs for 30 seconds and stops
It could be shutting off because of the heat sensor on the magnatron is over heating because of a bad capacitor or diode or the power transformer its self. This is a call for the service man BUT you know these days a microwave like this cost a couple of hundred bucks maybe a little more too. But it will possibly cost 150 or so if not more to fix the average microwave. If you really like it, then see if you can have it estimated BUT its not for the handy man to try to trouble shoot as theres extremly high voltage in these puppys even when they are not plugged in!! Good luck
Jun 08, 2006 | Panasonic NN-P794BF 1250 Watts Microwave...
Microwave Ovens Logo
165 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
