Question about Exercise & Fitness
Turn on and speeds up on its own
Upon setting speed to 1mph it will speed up to 10mph
    New Friend:
  • 4 Answers
Ghost have possessed it, holly water must engulf it
Posted on Apr 03, 2015
Speed will not slow to minimum
Check the voltage selector on the machine. Many models offer a selection of 50 or 60 Hz which will affect motor rotation speed. Std US power is 110 Volts AC at 60 HZ. Some equipment is made for several markets and can be switched from one voltage source to another. If that doesn't apply to your machine, try reversing the polarity of the outlet you are using to plug it in. (Most have three conductor grounded outlets, so you will need to use an adapter with a green wire coming out of it. File the bigger blade on the adapter down to the same width as the other smaller one and use your treadmill with polarity reversed to see if that cures your ill.) If it does and you don't feel comfortable changing a simple wall outlet polarity with the proper circuit breaker "off" then have an electrician do it.
Mar 04, 2015 | Image Advanced 1400 Treadmill Drive Motor
Whats wrong with audi a4 quattro when light on dash saying 1mph
Read your owners manual on how to set or clear your speed warning. There is nothing wrong with your car.
IIRC, the speed warning is zeroed by holding down the left instrument cluster button for more than one second when the vehicle is moving faster than 3mph. The icon will show with a diagonal bar through it indicating the speed warning is turned off.
Feb 12, 2015 | Audi A4 Cars & Trucks
How can I slow down a Sportcraft TX 320 treadmill?
Hi There, hmmm.... am I hearing that the treadmill starts too fast? At over 1mph? Most US treads will start at 1MPH and some will allow selection of .5MPH in the maintenance mode settings maybe. Otherwise, this could be attacked by a technical crew, like jatinah electronics possibly. If the treadmill would be set at one speed only that could be accomplished by reducing the drive signal at the component-level. It is certainly workable, but I would need to know what the current speed is that is too fast for her, and her ideal speed. ;o)
Jan 15, 2015 | Sportcraft Exercise & Fitness
When i start my proform 750 it doesnt slow down. It goes straight to max speed and never slows down.
try to calibrate the speed on the treadmill look in the trouble shooting section of the manual
Nov 04, 2014 | Proform 750cs Front Roller Model 299560
I have a MC2100-12A motor controller in this treadmill. The LED blinks quickly like communication is ok but it doesn't control right.The speed sensor also looks ok. When 1mph is selected it runs at 2.7mph...
The speed sensor on these machines have nothing to do with controlling the speed. The machine will run without it. The sensor is obviously working, since you are getting a speed reading.
The calibration is a mechanical adjustment found on the motor controller, the instructions are found under the lid as well as the meaning of the LEDs flashes on the tech sheet..
Follow the calibration procedure. If the operation is still erratic, I would suspect a defective controller.
Calibration: Press stop and speed up. Install the safety key/magnet. release the buttons. Press stop 1 time. one window displays speed, the other the calibration number. Both should be "0".
Press speed up, the treadmill should begin to move around 25-30. increase to 85, the machine should be a max speed. adjust the pot on the motor board to max speed. Some machines are 10mph, others 12mph. The tech sheet will tell you the max speed. When adjusted, press speed down. the machine will stop. Now press incline up. That will calibrate the incline. When completed, remove the safety key.
If operation is still erratic, change the motor controller.. It could be the console, but the cost of replacement makes the repair in most cases uneconomical..
Dec 15, 2010 | Exercise & Fitness
My proform treadmill goes 10 mph no matter what speed it's set at
That treadmill has to be calibrated upon replacement of controller. Contact the place were you bougth controller and request calibration procedure. Hope this helps.
Apr 28, 2010 | Proform CrossTrainer Treadmill
My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have an A3, a beep keeps coming on
Does it beep when you start driving?
If so, you might have your speed warning set too low. These cars have 2 speed warnings. Speed warning 1 resets each time you turn off the ignition. Speed warning 2 is stored in the memory. It sounds like you have a problem with no.2, but it's weird because I'm pretty sure the warning has to be set to at least 3mph. Your owner's manual shows you how to set the speed warnings under "controls and equipment - driver information displays."
The temperature reading is just the ambient (outside) air temperature.
Hope this helps.
Apr 29, 2009 | 2005 Audi A3
I have got an audi a4 tgi 1.9 and there a flashing light a circle and a 1mph showing.shows up when i go over 50 miles
LOOK UP YOUR MANUAL, YOU CAN TURN THIS OFF..ITS A SPEED WARNING FUNCTION TO HELP PREVENT YOU EXCEEDING A PARTICULAR PRE-SET MAXIMUM SPEED.RESET THIS.....
Mar 29, 2009 | 2000 Audi A4
Adui a4
IT IS A SPEED WARNING FUNCTION YOU CAN SET IT TO GIVE YOU A AUDIBLE WARNING IF YOU GO ABOVE YOUR PRE-SET MAXIMUM SPEED
Jan 08, 2009 | 2003 Audi A4 Cabriolet
Exercise & Fitness Logo
78 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
