Question about Reebok Exercise & Fitness
I can not get the new battery to go in place and there is no instructions in the manual .
    New Friend:
  • 4 Answers
What motor are you adding a batttery too? car,toy,cellphone ext;
Posted on Apr 03, 2015
INSTRUCTIONS SHOW PLACES FOR 4 BATTERIES AND THE 1 WHERE THEY SHOW THE CLOCK BATTERY , OURS DOESN'T HAVE A PLACE FOR A CLOCK BATTERY?
Sometimes manufacturer make changes in model and keep old manual
Contact SEIKO USA (presuming you are from USA) And ask them for updated manual for your model. SPECIFY THEM YOUR MODEL!!!
http://seikousa.com/contact-us
Sep 30, 2015 | Seiko Musical Wall Clock
How do I install a new battery? The manual doesn' t cover this.
Many garden tractors have the battery located under the seat. Move the tractor to an area you can work easily in and shut off the ignition.
1 Access the battery / compartment.
2 Identify the (-) Negative and (+) terminals on the battery.
3 Note orientation of the battery (-) or (+) as it is installed in the tractor.
4 Place a piece of tape on the (-) battery cable's insulation and another near the (-) battery terminal.
5 Photograph the battery with cell phone, etc.
6 Remove any clamps or brackets if they will be in the way of removing cables.
7 Remove the (-) cable from the battery terminal first by loosening the bolt or screw with required wrench, battery pliers, screwdriver, etc. by lifting it up / sliding out of the terminal.
8 Remove the (+) cable from the battery terminal last by loosening the bolt or screw with required wrench, battery pliers, screwdriver, etc. by lifting it up / sliding out of the terminal.
9 Remove any clamps or brackets if not already done previously.
10 Lift the battery out of the compartment straight up without tilting to prevent spilling acid from the battery.
11 If acid is not already in new battery: place new battery on several layers thick of newspaper and
a add battery acid to new battery as per instructions included with the battery.
b Place caps on battery when filled.
12 Identify the (-) Negative and (+) terminals on the new battery.
13 Place a piece of tape near the new battery's (-) terminal.
Place battery into compartment so that it is in the same relative orientation as step #3 above. This will ensure both cables will reach the correct terminal on the battery.
13 Check installed battery to photo to be sure it is oriented correctly.
14 Install any clamps or brackets if they will not be in the way of installing cables.
15 Connect the (+) cable [no tape] to the (+) battery terminal [no tape].
16 Double check that the (+) connection is correct and tight.
17 Connect the (-) cable [with tape] to the (-) battery terminal [with tape].
18 Double check that the (+) connection is correct and tight.
19 Install any clamps or brackets if not previously done in step #14 above.
20 Dispose of newspaper, acid container, etc in trash.
21 Recycle old battery where new battery was purchased / collect deposit.
Done!
May 19, 2015 | Garden
Installing new battery
Turn the calculator over. Look for some small screws that fasten a 1 or cover to the body of the calculator. Loosen the screws and remove cover. You should find button cell batteries. Before removing them make a note of the sign you see on the batteries (+ or -) while they still in place. Replace the batteries with the same model or equivalent ones. Replace the cover.
For more detailed instructions consult your calculator's manual.
Jan 09, 2014 | Casio MS-80TV Scientific Calculator
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Battery Exhausted
You have to replace the batteries.
Here is a link that leads you to download the manual in english language for free. When you open the manual, you would see instructions on how to replace the batteries and the type of batteries which are compatible with your device.
Also, if you do not want to go to the manual, here is a step by step instruction on how the battery should be replaced.
1. Switch off your camera and open the battery/memory card chamber.(ensure that the power light and monitor have gone off before opening the chamber).
2. After opening the chamber, slide the orange battery latch upward and remove the battery using your hand.
3. Use the new battery to push or slide the orange latch upward and make sure that the positive and negative terminals of the battery are on the left and right side respectively(doing otherwise would damage your camera)
4. After pushing the battery in completely, the orange latch would lock into place and then you can close the battery/memory card chamber.
You should charge the new battery for a couple of hours before turning it on.
The device uses a rechargeable Li-ion battery EN-EL10.
If you need links on where you can purchase the batteries, you can comment here and i will send you some links.
Hope this solution was helpful? Please comment for more information. Thank you for using fixya.
Jan 16, 2011 | Nikon Coolpix S3000 Digital Camera
I have a new Nordik digital indoor timer TD133B. It has never displayed information on it's screen. The instruction manual indicates plugging it in for an hour to charge the battery. I did this but still...
Most plug-in timers have rechargeable battery that is not replaceable.
Instructions say: Plug in timer for hour and then unplug it to set programs.
Intermatic makes a couple plug-in outdoor timers with replaceable batteries that load from back of timer, but otherwise batteries are rechargeable.
If battery will not charge, then display doesn't show, and that signals the timer is no good.
Take timer back if you can, and exchange for another.
I was looking at timers in Walmart and Target yesterday (since my specialty, and interest is timers).
New plug-in timers are inexpensive.
Lowes and Home Depot also carry inexpensive plug-in timers.
Be sure to save timer instructions because generally, store-bought timer brands don't show manuals on-line. Except GE brand timers from Home Depot.
Add a comment if you need more help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Nov 25, 2010 | Hardware & Accessories
Elmo will not turn on, batteries are new
THE SENSOR IN HIM HAS MOVED.FEEL AROUND FOR IT THEN PUSH IT BACK INTO PLACE
Jul 15, 2009 | Gund Sesame Street: Elmo 25" Plush Doll by
Need new battery for Sony PEG TJ 27
Turn off the device after you save your important stuff to a disk, or memory card, Then place your new battery in it. Check your instruction manual for Manufacturer recommendations.
Mar 18, 2009 | Sony CLIE PEG-TJ27 Handheld
Repair Manual
you will remove the body screws ... slightly loosen the camera body until you can remove the battery cover out ...... replace with a new one ... fit the body back in place and put the screws back.........
Oct 19, 2008 | Nikon Coolpix L1 Digital Camera
New battery
just install the battery and plug in the ac adapter it will charge as you use the computer usually within 2 hours. you can go online to acer.com, support and downloads, user guides for you manuals.
Sep 10, 2008 | Acer Aspire 3000 Notebook
Exercise & Fitness Logo
881 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
