Question about Onkyo Tx-sv727 Audio Video Control Tuner Amplifier Amp Av Stereo Receiver Tested
How to turn off video 2 monitor without a remote - I do not have a remote, I have NO sound and Vid 2 moni is ON.
  • marlea ashirley Apr 03, 2015
    Correction, I meant to type "tape 2 monitor" not "video 2 monitor".
    New Friend:
  • 4 Answers
Alt ctrl and P should bring the program up and you can change what screen is your main, link both, or i think turn off
Posted on Apr 03, 2015
    My ONKYO TX-SV727 is connected only to my TV and speakers. I was going to use it for sound only, how would I alt+ctrl+P?
No video
try to reset the cpu or remove the battery for just a sec then back it up...
just turn it on..
if still...
try to remove the memory chip and clean on it..
replace to it and turn it on
Nov 28, 2011 | E-Machines eMachines Desktop PC
To whom it may concern. I own a RCA D52W23 Monitor and run it through a VHS recorder. The problem I am having is when watching non-HDTV channels,I can not see the top of the picture (Heads cut off).Only...
look through the video or setup menu and find Picture Format- make sure it is not set to ZOOM.
I believe "format" is also on the remote-- upper left?
Apr 13, 2011 | RCA D52W23 52" HDTV CRT TV
When trying to install a new video card, the manual said to remove current video drivers. I did so but it removed the onboard video driver as well. So now when I start it nothing somes up on the monitor...
Hello
If you have the cd or dvd for your new vid card,try installing the drivers from it.
Another thing to try is take the vid card out of thr slot and reinstall it back in again.
Feb 20, 2011 | HP Computers & Internet
E151FPp (Gray) 15 in. Flat Panel LCD Monitor: I am not able to get DIplay Driver for my LCD moni...
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Dell E151FPp 15" Flat Panel LCD Monitor
Monitor will not start up
possible causes
1) video card slipped out of the slot, after shut the system down try reseat the video card
2) video card faulty
3) video card cable faulty.
try with some other vid cable, if it doesnt work with above mentined 1 and 3, then card cud be faulty.
Apr 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
K7MNF-64 MB is no longer showing any display even at boot up
You shoould try a different video cable. If this does not work, you should make sure that the video card that you are installing to check are compatible with the system.
Nov 15, 2008 | FIC (51-81677-00) Motherboard
Monitor ont boot up
what do you mean 2Video cards? It doesn't post POST messages? of no video on Windows? please need more info to help you
Apr 03, 2008 | Compaq Presario R3000Z Notebook
Need code
i too went 3months with no remote or codes finally a young tech at walmart in another town told me to use 0171 code but cable guy set me up on cable remote to turn tv on and off tech told me to get a one for all remote 9.99 at walmart and code it but to also push setup code for tvdvd and enter code i use cable remote for tv viewing and the one for all to reach video 2 (press tv/vid button twice) for games and dvd player now i can access menu and use my tv as it should hope this helps
Jan 03, 2008 | iLO 3200 32 in. LCD Television
Onkyo Tx-sv727 Audio Video Control Tuner Amplifier Amp Av Stereo Receiver Tested Logo
55 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
