Question about Step2 Step 2 Play Up Toddler Swing & Slide
Where can I find a replacement safety harness ( the plastic piece that all the safety straps go through) and how much does it cost? for the step 2 toddler swing and slide
The plastic piece that the safety straps go through is cracked and needs replacing or the whole unit with straps needs replacing. Where can I find this?
How is the rear wiper cowling removed on a 2004 ford explorer?
This is a guide on how I removed my rear hatch panel so everyone else doesn't have to search through countless threads with vague instructions on how to do it.
Step 1: Remove the plastic pins around the top pf the hatch. These should be the same color as your interior. To remove them you can either buy the actual tool to do it at any local car parts store, or just take a set of screwdrivers and pry.
Step 2: Remove 2 screws holding the pull strap in. It's that little thing that hangs off the panel when you open the hatch up. The 2 screws are directly under the strap's base.
Step 3: Pop out the plastic piece from the lock indicator. It just pops out with a little prying from your screwdriver.
Step 4: Remove a screw next to the lock indicator. It should be underneath where the plastic piece we just pried out was.
Step 5: Yank the panel off. To do this, pull it towards the front of the truck, and it shoulc just pop out. You may get all the front clips and need to force the rear clips forward by hand.
To replace it, just do the steps in reverse.
Oct 21, 2016 | 2004 Ford Explorer
How do you adjust straps on a baby car seat?
Graco SnugRide 35 : Adjusting Harness Straps - YouTube
? 6:41
https://www.youtube.com/watch?v=vl_JSaEuu0U
Jun 23, 2012 - Uploaded by Baby Car Seat Installers
This video shows how to adjust harness straps for the Graco ...Graco SnugRide 35 : Adjusting Harness Straps. Baby Car SeatInstallers.
Britax B-Safe: Adjust Car Seat Harness Straps - YouTube
? 3:12
https://www.youtube.com/watch?v=XGHnSLXRqq8
Mar 2, 2014 - Uploaded by Baby Car Seat Installers
We teach you step by step on how to move the harness strapshigher as your child grows. This video is for ...
Nov 17, 2015 | Cosco Baby Gear
I'm struggling to adjust the safety harness on the
You're right, the straps shouldn't be choking your son, but it could be that he isn't' quite tall enough for the chair yet and needs a booster insert so he is sitting higher?My kids all needed an insert for quite a long time before they could be strapped in without it.
Jun 05, 2012 | Baby Gear
I have taken the straps & small black adjuster completely off the car seat so I could put the straps in the wash. I cannot re-fit this black plastic adjuster back onto the car seat no matter what I...
Good Afternoon
The harness should never be completely removed due to the safety implications of it being incorrectly re-fitted.
Please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss booking the carseat in for our engineers to rectify it and what the cost will be.
Aug 13, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How to install wiring harness
Step 1
The first thing that must be done is to strip the wires so that about a quarter of an inch is showing of the wire that comes out of your CD player's wires. Every single wire which is about 12 wires or so, must be stripped in order to proceed to the next step.
Step 2
After your wires are stripped. Take the new wire harness, the one I'm assuming you made sure is fit for your model of vehicle. You could buy these harnesses at BestBuy or your local car audio store. Take the harness and if you got a good quality harness it should be already stripped. If they're not already stripped, then strip them.
Step 3
Now here's the tricky part that's only tricky until you read this step.
Just match up the colors from your CD player's wires, to the wire harness's wires. That's right, it's as simple as that. Twist the wire from the CD player and the wire harness together about 4-7 times until the wire is secure.
Step 4
A crimp set includes little plastic bits that the 2 wires go into when twisted, then the wire put in the plastic bit and the plastic bit is then pushed down with force (crimped) to secure the wires from coming apart or touching other wires. A good note to remember is that if the blue wire from the CD player doesn't match a wire on the harness, then that is okay. Just crimp the blue wire by itself. The blue wire is used for aftermarket amplifiers to tell the amplifier to turn on when the radio is on.
Step 5
To avoid any incidents, unplug the negative (black) part of the battery on your car. Now plug the end piece of the wire harness (the plastic piece), into the car's radio input (car's plastic piece). If they 2 harnesses do not fit together than you have made a mistake and purchased the wrong harness
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 13, 2010 | Dell Dimension 4600 PC Desktop
I dissasembled the car seat so I need get manual in order to re-assebly the belts in the correct way , can you help me
I just noticed my car seat had a safety recall back in 2007 and noticed you had the same recall on the 22150. I just ordered a new kit from Cosco (which was free) to replace the faulty parts. Here's the recall notice ans website to go to: http://www.safety1st.com/usa/eng/News/Detail/309-
Click on "Harness Adjustment Strap Inspection" and give your info. to order the kit.
News 8/30/2007 12:00:00 AM
Dorel Juvenile Group Announces a Voluntary Safety Recall of the Harness Adjustment ******** Certain Cosco®, Safety 1st® and Eddie Bauer® Brand Child Restraint Systems
Columbus, IN August 30, 2007- Dorel Juvenile Group (DJG) is issuing a voluntary safety recall for certain Cosco®, Safety 1st® and Eddie Bauer® brand child restraint systems manufactured during November 2003 through December 2005. Although no injuries have been reported, there is a potential for the harness adjustment strap to loosen during use. If this were to occur, the harness may be loose around the child, possibly increasing the risk of injury in a crash. We feel that it is important to replace the harness adjustment strap.
Model numbers affected are:
Cosco®: Alpha Omega®, Alpha Omega EliteTM: 22150, 22155, 22180, 22269; Eddie Bauer®: 3-in-1, Deluxe 3-in-1, Deluxe Convertible: 22740, 22750, 22755, 22756, 22757, 22770; Safety 1st® : Alpha EliteTM, Alpha Omega®, Alpha Omega EliteTM, Alpha SportTM, InteraTM, EnspiraTM: 22151, 22450, 22451, 22452, 22453, 22455, 22460, 22480, 22481
The model number and date of manufacture may be found on a sticker located on the side or back of the child restraint system.
DJG will contact all registered owners and provide them with information on how to obtain a free repair kit to replace the harness adjustment strap. Those consumers who have not registered their product should visit www.djgusa.com or call 800-219-0509 to order a free repair kit. The affected seats should not be returned to the retailer.
DJG encourages parents to obtain and install the repair kit as soon as possible. Parents may continue to use the child restraint system as directed in their instruction manual. Parents should be sure to adjust the harness adjuster strap snugly each time they put their child in the child restraint system. If there is any difficulty adjusting the harness adjustment strap, or it does not remain tight, DJG suggests using a different child restraint system until the repair kit has been installed.
To check for harness slippage:
(1) Fully tighten the harness, (2) pull on the harness straps without pressing or lifting the harness adjustment lever. If movement occurs, the harness is experiencing slippage.
Jul 04, 2010 | Cosco Alpha Omega Convertible 22-150
How to remove tail light assembly on 2005 town and country
The step by step procedure is given below:
1) Open the tailgate. Adjacent to the tail light inside the are 2 round, black plastic pieces that hold the light in place. Use a pliers or screwdriver to pull or pry them out
2) The tail light assembly will swing out because the front is held in place by a simple tab.
3) Find the small red plastic piece that locks the wire harness pieces together: slide it to unlock the harness
4) Pull wire harnesses pieces apart, put the new one in it's place, then reassemble.
Nov 08, 2009 | 2003 Chrysler Town & Country
Electrical problem with the dash.
This wiring problem can be much more costly, and time consuming, than you want to take on.
Professional mechanics cringe, when a wiring problem of this magnitude comes their way!
It's probably a bad ground for the instrument cluster.
The instrument cluster housing is plastic. There is a flat, thin, 2 to 3 inch wide, piece of plastic that is the wiring harness for this instrument cluster.
In this flat piece of plastic, are thin flat copper strips. These are like wires, to conduct the electricity to the gauges, lights, and the rest of the instrumentation.
Since the plastic instrument cluster is not metal, and therefore it can't be used as a Ground source, the flat piece of plastic I mentioned above, has a Ground wire to it. May be more than one.
This ground wire/s could have corrosion on the terminal end, where it attaches to the truck body.
Bad ground, everything goes haywire. The ground wires, might loose on the terminals used for the flat piece of plastic.
Another source of a bad ground problem overlooked, is that the cab of a truck receives it's,
Main ground from the engine.
There should be Two ground straps, coming from the firewall over to the engine. Sometimes, when the upper part of an engine, or the engine is replaced, the mechanic neglects to reinstall these ground straps.
Sometimes just one ground strap is reinstalled, and this is No good!
Also both terminal ends of these ground straps are a good source for corrosion to develop.
Corrosion makes a bad contact.
I myself would take the truck back.
Apr 19, 2009 | 1998 Chevrolet S-10 Pickup
Lost piece of Harness
You can get replacement buckles at Babies R Us. They are also known as harness ties. They may be available at other stores like Target etc. You can also order one from Graco, but it will be a bit pricey with shipping costs etc. -Vish
Oct 04, 2007 | Graco 8A00PSN - Pierson
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Step2 Step 2 Play Up Toddler Swing & Slide Logo
21 people viewed this question
Top Step2 Toys Experts
ray gallant
Are you a Step2 Toy Expert? Answer questions, earn points and help others
