Question about Retail Supplies
How do you program tax rate? - Retail Supplies
  • Retail Supplies Master
  • 1,780 Answers
Every machine has different codes for programming tax. You need to get the codes and programming lines from the programming manual. One of the users has most of them here:
https://the-checkout-tech.com/
Posted on Apr 05, 2015
I have a TE-2200 Casio cash register. I try to program in tax rate and nothing happens. Can someone help
If you have changed the tax rate, it should print out the change you made to confirm the change as soon as you finish programming. After that, it should use the new rate. If it is not adding tax to items, make sure you have linked the tax rate to the items in PLU or dept programming (whichever you are using)
Apr 08, 2018 | Retail Supplies
How to program tax into only one department. I have entered the tax according to instructions but it automatically puts tax on all department keys.
You set the rate in the tax rate program then you set each department as taxed or no tax. If it is affecting all depts, you need to look up department programming and set tax (usually tax1 to 0 or off) in each dept
Sep 28, 2017 | Retail Supplies
How to program two non cumulative taxes on a Casio PCR-T2000A?
Firstly, change the rates for each tax in the tax rate setting tables of your manual. Then you need to turn on tax rate 1 and 2 for departments that need both. This is done in the department programming tables. Tax setting can be quite involved so follow the tables carefully.If you need a programming manual, One of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Dec 31, 2012 | Casio Parts Cash Register PC Desktop
Hello, I have a cash casio PCR-T275 I want that tax2 is taxing tax1. By example, if I have: 10$ tx1 (5%) = 0.50$ subtotal: 10.50$ tx2 (8.5%) = 0.89$ (tx2 applicable on tx1) Total: 11.39$ (NOT...
While you can't have the second tax rate tax the first as you described in the example, you could program the %+ key to be your first tax of 5% and program the tax rate 1 to be 8.5...so ring $10.00, then hit the 5% service chg,(programmed to be taxable by rate 1) then subtotal...should tax the whole amount
Jan 03, 2011 | Casio Parts Cash Register PC Desktop
Programming tax on a casio pcr-t2100
Key to Program enter 3 subtotal 1 tax pgm (tax rate with decimal) cash tend subtotal.
ie 7.35%
3subtotal1 tax pgm 7.35 cash tend subtotal
Oct 12, 2009 | Casio Parts Cash Register PC Desktop
How do I program the calculator tax+ Tax- buttons?
1. How to set/ change "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator,
1. Press [AC] and hold [%] for about two seconds.
2. Input Tax Rate and then [%].
* You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator,
2. Input [TAX+].
3. Input Tax Rate and then [%].
2. How to calculate Price-plus-Tax and Price-less-Tax.
(1) How much is Price-plus-Tax of 100?
Press [AC], and input 100 and then press [TAX+].
Calculator will display 105 if tax rate is 5%
If you press [Tax+] again, it will show the tax amount..
(2) How much is the Price-less-Tax of 105?
Press [AC], and input 105 and the press [TAX-].
Calculator will display 100 if tax rate is 5%
If you press [Tax-] again, it will show the tax amount..
Jul 29, 2009 | Canon LS-100TS Calculator
I need to change the tax rate on a royal alpha 600sc
To program a sales tax rate of 6%
1 Find your sales tax rate. You may need to contact your local government
office.
2 Put the PRG key in the Mode key slot and turn it to the PRG position.
3 In the round Number keys area, press 1 and then press the Tax 1 key.
4 Press 6000 and press the Amount Tend Total key. Your sales tax is
programmed.
Apr 01, 2009 | Royal DM3070
I need to know how to program a new tax rate
move the pgm key to pgm mode 3 subtotal 125 subtotal ( tax table) rate tax and subtotal beginning  level tax ejemplo : for ten cent = 10  and subtotal 5002 subtotal subtotal.
to applay the tax to dept or plu
move the pgm key to pgm mode 3 subtotal 366 subtotal 1 and all dept o plu  subtotal
Mar 31, 2009 | Casio Parts Cash Register PC Desktop
How to program tax rate for te-2200
Hi. If you bought it new then your dealer should have set all of the system options for you so it is strange that the tax is not programmed. Normally you would only need to set the rate when your tax rate changes. Has it been calculating tax at all? Did it come from your dealer with a standard program in it?
Nov 26, 2008 | Casio Parts Cash Register PC Desktop
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
128 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
