Question about DCS Ovens
My thermostat went out on my DCS RG-366 oven. I may have wired it improperly. Can you share the wiring diagram for this part? I do not have the paperwork normally found in the kick plate.
  • 2336 Answers
SOURCE: Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
If you have this user guide go to page # 40 for wiring instructions.
Posted on Apr 09, 2008
captaynkyrk
  • 170 Answers
SOURCE: Thermostat for kenmore oven wiring
Here's a link for you: http://www.partselect.com. You can put in your make and model and get diagrams of your appliance and see how things connect. Good luck!
Posted on Jul 20, 2008
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
danforddan1
  • 192 Answers
SOURCE: wiring diagram blodgett sho-e convection oven
I dont know much about Blodgett ovens other than how to bake in one and that are top of the line. I use to live next to the factory where they are made. On beautyful Lake Champlane Vt. Go here http://www.blodgett.com/convection_full.htm
you can contact them by phone.
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-018
how about that. please rate me Thanks
Posted on Apr 22, 2009
  • 250 Answers
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Posted on Jan 26, 2010
My DCS WOS-230SS top wall oven begins to heat up normally but then stops heating, the fan comes on, then begins heating up again. Got to 170 then went no higher. Could it be the element?
This is a tough question because we haven't mention the make and model number you should add that so we can help you better but normally if the top oven is not working properly it may have thermostat problem or it could also be control panel problem can you tell more information especially the make and model
Sometimes you can take it out and it's not working properly and take that oven and put it in self-clean mode and it might fix problems
Mar 27, 2018 | DCS Ovens
I have a DCS-FSCO-1N oven that a repairman took apart & then took off before putting the new part back in. Is there anywhere to get the wiring map or schematics?
IF DCS is still in business contact them, explain the situation and ask why they would have such a technician that would do such a thing. There is also a very good chance he took the diagram with him as most major appliances have diagrams in the unit for all repairmen to use. Good chance they will resolve it through their own service agency. If not, ask if they would at least send you a pdf of the diagram to download and print.
Jan 06, 2015 | Ovens
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
DCS gas oven and broiler that pulses
This sounds a lot like a defective pressure regulator. If you do not have one externally connected, then the internal regulator is faulty. If internal, it shouldn't be too difficult to DIY. Just make sure the pressure rating is the same as the one that has failed.
Mar 24, 2010 | New World G60m Gas Single Oven
Need a service manual for wo-127ss DCS single wall oven. need to replace the control board because my display light went out. How do I take it apart?
you can call dcs, they will be happy to send you a manual,
but mostly, this should be pretty simple, three small black phillips heads hold tthe console down, the are above the door when closed
from there the panel should tilt forward and off
becareful they dont leave much room. or very long wires
Oct 13, 2009 | DCS (WOTD-227) Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
Open Questions:
Ovens Logo
204 people viewed this question
Top DCS Ovens Experts
Sal De
Joyce Nokleby
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
