Question about Consew 199R-1A Sewing Machine
Help , Entire tension spring assembly fallen out and won't stay back in situ.
Today i loosened the screw in the centre of the tension spring assemble , as I just can't get tension correct. and the whole lot has come out. I cannot get it to stay back in situ. I have feed far end ( back edge) of spring into grove in shaft, feed tension spring into slot on outside of machine to allow it to move up an down? Really need to get this mending, work mounting up! Thanks
    Master:
  • Consew Master
  • 470 Answers
Posted on Apr 03, 2015
Testimonial: "Hi William , thank you for your suggestion. I actually have the original manual and from that followed instructions to loosen the central tension spring screw. I can't find any mention of how to put it all back together, I fit all pops out!"
How to disassemble
The entire tension assembly will come out intact. There should be a screw (usually about 8-9 oclock) that holds the unit in place. Loosen it and pull assembly out. There will be another screw that holds the big round part (that was back in the machine before removing). Loosen and slide off, then remove and replace spring. Make sure when you install that its not in too far that it keeps your tension discs open all the time or you won't be able to adjust the tensions.
Aug 06, 2014 | Consew CN2053R1 Sewing Machine
Elastic thread pulled too tight in Janome Sewist 525S
I would say your tension spring is shot on your tension assembly. replace it.
Mar 27, 2017 | Janome Sewist 525S Mechanical Sewing...
Why will the tension unit will not stay in
loosen the screw that holds the tension device in place and remove the whole thing. if it won't pull right out use a small screrw driver in the take up spring slot to help it out. probably whats wrong is the small screw at the rear of the tension device is loose. u need a very small screwdrive to tighten this and don't put tons of pressure on the screw only to have to drive slip off and slice your finger. don't misplace the pin that opens the thread tension disksn when presser foot is up position.
Jun 20, 2014 | Juki DDL-5550 Industrial Straight Stitch...
I need instructions on replacing the thread take up spring Juki DDL 8700
contact a juki dealer to see if they can give instructions
Jan 31, 2012 | Juki DDL-8700
Hi! i was just gifted w/ a kenmore sewing machine model # 12121 i havent even plugged it in yet. I noticed that the top thread tension control knob has fallen off. it appears to have all its pieces, but i...
Open the left end door that accesses the light. On the edge of the casting by the tension control, you'll see a set screw tapped into the hole that the upper tension control fits into. That set screw locks the tension unit into the casing. If the upper tension unit is in peices, you'll need a diagram to re-assemble it correctly. If you don't assemble it correctly, it will NOT work right.
Jan 03, 2011 | Kenmore Sewing Machines
I have a singer 4538 and the top tension is ok, I believe. The bobbin tension is too tight. I took out the bobbin case. It has two screws. The one on the left can be loosened, but doesn't help the...
one screw should stay tightned .. the other is the adjustment ... you will notice that the correct screw is adjusting the force on a flat spring .. that spring is what provides the bottom tension .. when the thread is properly positioned then it will be pulled under that spring .. you should be able to pull the thread with just a small amount of drag .. the top tensioner should have about the same amount of drag when set to about 2 of its adjustment range .. usually the foot has to be down to engage the top tension ... you normally dont need oil on the bobbin case .. the screw you want is about in the center of the flat spring ... if you cant adjust the bottom tension then take the flat spring all the way off and see if there is thread or debree keeping it from operating properly .. make sure there are no sharp edges or burrs in the thread path ...
Jan 03, 2010 | Sewing Machines
My top stich thread loops and my bottom thread is straight but my tension feels equal on top and bottom
reset the top thread tension take-up spring - not the discs, the small, U shaped spring the thread goes through after the tension discs. Loosen the screw and turn the assembly down to add more tension to the spring.
Aug 12, 2009 | Consew 226R-1
Replace the needle thread tension dial
If the entire assembly has fallen out you will find if you remove the top left hand cover that there is a small screw in the casting where the tension assembly goes, replace the tension body to the correct position and tighten the little screw.
Jun 30, 2009 | Singer Tiny Tailor TT700
Tension disc assembly - sewing machine
Sorry but there is no way to explain how to re-assemble the tension mech on here, you need to be actually shown or have someone do it for you. It is very fiddly and needs to be exact, can I suggest you get in touch with a sewing machine tech who(at cost) will sort you out.
Sorry I cannot be of any further help.
Rob
Mar 24, 2008 | Sewing Machines
Consew 199R-1A Sewing Machine Logo
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
