Question about Samsung UN50ES6100 50 Inch 1080p Smart TV LED LCD HDTV
Problem with vertical shaking from DVD player with standard cord.
The movie is Frozen..."non cartoon" DVDs don't have this issue. Is there a setting to be adjusted - other than energy saver settings...they are all turned off. The DVD player is a SONY video DVD combo - RMT-V501E - but again all other DVD's are fine...
SOURCE: samsung dvd combo player.
sell me your unit!
Posted on Jan 28, 2008
  • 236 Answers
SOURCE: DVD video player problem
your laser is getting weaker now, if you have thoroughly cleaned then it needs a replacement now.
Posted on May 04, 2008
rdoell
  • 7 Answers
SOURCE: Connection cord problem from VR375 to TV set?
Page 18 of the user manual for your device shows that there are normal video (yellow) and audio (red/white) connectors underneath the A/V out column of connectors - Since your son's TV does not have an HDMI cable (all you would need if that were the case) make sure you connect the A/V out column to the RCA type inputs of your son's TV.
The manual can be found here:
http://downloadcenter.samsung.com/content/UM/200802/20080229102004125_01613A-01-VR375-XAA-ENG-BM-0228.pdf
Posted on Jan 01, 2009
SOURCE: Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Posted on May 28, 2009
SOURCE: I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Posted on Nov 24, 2009
DVD player will not play a standard DVD after playing a Netflix movie
Could be a region setting issue. Go to DVD preferences and restore defaults. Try running your standard DVD from an outboard player and see if it works. Check your region setting- should be Region 1 for American DVDs. Any error messages?
Feb 16, 2015 | Apple MacBook Pro - Core Duo 2.16 GHz -...
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
Mar 01, 2014 | LG 37LP1D 37 in. LCD Television
My pioneer dv-120k wont play australian or us cd's. Only home burnt copies of movies.
dvd players because of copyright info can only be set to one region code and can only play dvds from that region. Some players are set at factory some allow user to reset region usually a limited no. of times.
home burnrd dvds usually don't carry that info therefore no issue. So you need to reset player for appropriate region
Jan 12, 2014 | Pioneer DV120K Player
Broken Remote how do I get a replacement or get it to work with a dvd player
Try website like Remotes.com to buy the tv original remote.Little more exspensive than those universal remotes.Don't tries this tv with those universal remotes,it will not work or have universal codes for this tv.This tv was a specially manifacture for the Disney Corporation only for briefly period of time only by an small un known electronic Corporation for the late 90 Aminations cartoons movies fads only.
May 27, 2011 | Disney 13" TV
My BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
Is there anyway to decode movies so I can transfer movies (boughten) to dvd? I have over 400 movies and would like to put them on dvd so they store more compactly!
Use MediaCoder. It will convert any movies you have to any file format that you want, preferrably .mp4 for movies or .avi. The standard DVD format is .VOB, and you'll have a hard time finding a program that can read those for free. Using MediaCoder you can convert them to the much smaller .mp4 format and put them as data files onto a DVD or actual watchable DVDs.
Sep 03, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Jun 13, 2009 | Sony PlayStation 2 (PS2) Console
Zenith DVD Player--DVB410/ZND400
I got two new disks to-day with pictures taken from 35mm slides. They will not play on my zenith znd400 dvd player. I wonder why??????
May 10, 2008 | Zenith DVB412 DVD Player
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Mar 31, 2007 | NAD C541 CD Player
Samsung UN50ES6100 50 Inch 1080p Smart TV LED LCD HDTV Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
