How do I replace the transformer? - Heating & Cooling
    New Friend:
    Problem Solver:
  • 19 Answers
#1turn high voltage off to the unit service disconnect or at your panel box.there will be two wires comeing out one side of transformer. And could have four out other side .I dont know what t-from. You have .take notes and pic with your phone if you can there should only be two wires for your low voltage wireing and two for your high side.on high voltage side it will show you one wire as common usealy its white than pick other color for what voltage you have going to unit 110 or 240 volt s.the old t-from should have wireing diagram on it .cut wires by old transformer just cut wire at wire nuts leavening color of wire and wire nut so it stays with wireing to old transformer at this point hopefully you should be able to follow what wire goes to wire on transformer. If you have any extra high voltage wires just wire nut them separately only useing two.I hope this helps without seeing t-from its hard to be exact but just be very aware of what wire goes to t-from and you will be ok .note dont go by color sometimes color s will be different on each t-from
Posted on Apr 03, 2015
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 | Drills
Transformer replacement
primary side = voltage being supplied to transformer......secondary side = voltage output on transformer. hot line to hot line, neutral to neutral...........rtfm......read the manual
Dec 05, 2013 | KitchenAid Refrigerators
Fix power supply burned out transformer
test transformer for contunity if not ok ,then then replace internal termalfuse in transformer
Nov 13, 2013 | Bang and Olufsen Audio Players & Recorders
How easy is it to replace an intermatic ML300RTW malibu tranformer?
Question is not 100% clear.
Add a comment any time, and that sends email, and I will respond with more information if needed.
1) Are you trying to repair a transformer?
I do not know of any repair for the transformer, or available parts sold to repair transformer, although the product does have a warranty, and Intermatic might have a repair protocol for the transformer.
http://www.intermatic.com/customer%20service.aspx
2) Are you replacing existing transformer with a new transformer?
The transformer plugs directly into outdoor outlet, and wires are connected to A and B terminals.
Open following link to read how to set up and use transformer in troubleshoot-format:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Sep 17, 2011 | Intermatic Malibu 300W Power Pack...
No power past what I think is the transformer? My gauge indicates there is power in the main power cord. Thank you.
Can you test to see if power is coming out of the transformer thing? If it's not it could have failed. Some transformer have an internal fuse. Unfortunately these are generally not replaceable so the transformer has to be replaced. Transformers are also safety parts, so have to be replaced by manufacturer's replacement parts.
Jan 31, 2011 | Crosley CR-84 Turntable
Pendant lights with Novitronix 9801AR transformers
You can use the following transformer as a replacement-
  • LET 60 class 2 12 V/60W lighting transformer from express lighting.com $18- slightly smaller
Had the same problem- customer service at home despit was underwhelming as usual, they said that each manufacturer blamed the other, and to return it, they would not just replace the transformer. Typical of HD-you are pretty much on your own-lucky im an electrical engineer!-hope this helps
Nov 08, 2009 | 2001 Buell X1 lightning
Replacement substitute for Fender Sunn power transformer 28-4150
I can't find a schematic that references the transformer and cannot find a replacement either. I'd contact Fender for a reccomended substitute.
Jun 22, 2009 | Music
Altec Lansing ADA 880 Toroidal Transformer Replacement
Did you solve this? Cause I have the same problem and need some advice...
~Brian
bwalker1978@yahoo.com
Mar 23, 2009 | Altec Lansing ADA 880 Computer Speakers
Blown power transformer
Hi
What has happened to the transformer. Does it have an open circuit primary?  Get back to me if you want a fix.
regards robotek
Dec 12, 2008 | Audio Players & Recorders
Goodman central unit not functioning
You may be putting the incorrect transformer in. Try to get a OEM from your local HVAC dealer. Which capacitor are you referring to?
Mar 29, 2008 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
