Question about Kenmore Dryers
Propane Kenmore front loader dryer drum won't stop spinning and there's no heat.
    Habit-Forming:
  • 120 Answers
EITHER OUT GOT A BAD DOOR SWITCH AN. BAD PART THAT CONTROL THE GAS TO YOUR DRYER BUT SEND THIS IS A PROPANE GAS DRYER IF U NEVER WORK ON ONE IT BE BETTER FOR U AN YOUR FAMILY SAFE TO CALLL FOR SERVICE
Posted on Apr 03, 2015
larryyb
  • 291 Answers
SOURCE: our kenmore dryer drum doesn't spin
2 to 1 your belt is off or broken / if lower panel in front will drop down you can see from there
Posted on Dec 05, 2008
jaballou
  • 63 Answers
SOURCE: dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Posted on Dec 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer does not heat.
DEAD DRYER
Posted on Feb 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Posted on Apr 08, 2009
  • 24 Answers
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
My dryer stopped spinning and it won't heat. it just makes a click sound inside the dryer.
Dear Sir:
See this possibles causes:
Power from the house
Test the main cables from your house, and the dryer for continuity see the diagram attached
Heating element
one heatings elements burn or open, test for continuity.
Thermal fuse
test the fuse for faulty or open, continuity and replace it
Wiring
test for wires burn or break, see for continuity.
God bless you
5_24_2012_10_33_43_am.gif5_24_2012_10_33_58_am.gif5_24_2012_10_34_21_am.gif5_24_2012_10_35_06_am.gif5_24_2012_10_35_28_am.gif
May 24, 2012 | Samsung Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
I have a Kenmore 90 Series gas dryer model num 11074902200 that won't heat up. the drum spins and the heat will turn on for a few minutes then it stops heating up. I replaced the glow igniter but the...
The flame sensor is fine because it is powering up the ignitor. The dryer does heat a little. It can be only one thing: The solenoids are aged and weak. They work at first then the heat up and quit.
How to video
Service manual and more HERE
Sep 08, 2011 | Dryers
Kenmore propane clothes dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Dryer spins and drum turns, but only cold air c...
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
My kenmore dryer heat very good but the drum stop working it dose not spin at all
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
