Question about Kenmore Washing Machines
Kenmore front loader drum won't stop and no heat
  • Kenmore Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Posted on Apr 16, 2015
  • 10 Answers
SOURCE: kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Posted on Nov 04, 2007
  • 1314 Answers
SOURCE: Kenmore front loader washer
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Posted on Jan 25, 2008
jsrock516
  • 5911 Answers
SOURCE: How do I stop my Kenmore front loader from leaking
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Posted on Jan 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore front loader drum makes a very loud
It appears your drum roller/glides has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore 40412 front loader washer has 2 braces on
Shipping pins.
Just to secure the drum.
Posted on Sep 19, 2010
Propane Kenmore front loader dryer drum won't stop spinning and there's no heat.
EITHER OUT GOT A BAD DOOR SWITCH AN. BAD PART THAT CONTROL THE GAS TO YOUR DRYER BUT SEND THIS IS A PROPANE GAS DRYER IF U NEVER WORK ON ONE IT BE BETTER FOR U AN YOUR FAMILY SAFE TO CALLL FOR SERVICE
Apr 03, 2015 | Kenmore Dryers
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Kenmore 40412 front loader washer has 2 braces on the front of the drum to the frame that are broken. Are these necessary or used for shipping? They are 3/8 rods.
Shipping pins.
Oct 15, 2009 | Kenmore 44042 Front Load Washer
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front loader object stuck under drum
Sugest you remove the heating element and use a torch to see item through hole then pull out in the best manor possible.
Sep 24, 2009 | Kenmore 46462 Front Load Washer
No heat, motion, but light is on and timer ticks
Check the thermal fuse on the blower housing. It is for over heat condition and non resettable.
eric
Jun 29, 2009 | Kenmore Dryers
Washer is louder than normal The drum seems to
the bearing assembly is beginning to fail.
requires an overhaul.
this problem is far too common with Kenmore and frigidaire front loaders
Mar 24, 2009 | Kenmore 43042 Front Load Washer
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Robert Rankin
