Question about Dishwashers
Most buttons on the control panel do not work. The only 3 working buttons are high temp wash (htw), sani rinse, and heated dry (hd). We tried resetting the console by hitting the sequence of htw, hd, htw, hd. This caused all the button lights to be lit and then it proceded to start and complete the diagnostic cycle (turning on and off appropriate lights during cycle.) However, the buttons still don't work. Not even the cancel or start buttons. We also had previously checked the thermal fuse and door close sensor were okay.
    Champion:
  • 208 Answers
Spray some electronic cleaner on the plugs in the rear of the touch padight be so corrosion build up on the board.
Posted on Apr 04, 2015
Testimonial: "Thanks for the suggestion."
  • 3 more comments
  • Trevor Turner Apr 05, 2015
    If it helps, post it so others may be helped with this type of issue. Most touchpad issues are solvable just by doing this! Good luck.
  • Lynn Wright
    Lynn Wright Apr 06, 2015
    No corrosion seen there.
  • Trevor Turner Apr 06, 2015
    Spray a cleaner on it and the plugs anyway... Sometimes it won't be obvious. You can find this product at a computer shop/ repair shop.
  • Lynn Wright
    Thanks, but we've decided to buy a new dishwasher.
  • Trevor Turner Apr 07, 2015
    Sometimes this is the best decision.
  • 473 Answers
Shut power off to dishwasher for about 5 minutes and see if control panel will reset. This sometimes helps. If problem is still there you may have a bad control board.
Testimonial: "Already did this several times."
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
My soap dispenser will not open during the wash cycle
There is a quick test to verify there is a problem, this test will take about 2 mins. Open the door, close the dispenser (latched), on the control panel itself, push in this order hi temp wash (HTW) than sani *3 times in that order*. So that means HTW-Sani, HTW-Sani, HTW-Sani. What this will do is run a control service mode, all the LED's will light up, close the door and wait until it stops, within about 45 seconds you should hear the dispenser open. If it opens it is functioning normally, if not, it should be replaced.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 29, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
LIGHTS FLASHING ON THE PANEL
If the reset procedure (those buttons you pressed) didn't work, it's because the machine is still reading a fault. It could be a few things... water temperature too low (indicating a bad heating element), partial blockage of the drainage hose, or something preventing the spray arm from spinning. If letting it sit for a while allows it to start again, I suggest you do that. It will stop again and the lights will start blinking. When it does, open it up immediately and see how much standing water there is. If there is a lot, look for a blockage in the drainage hose. That's the most likely, I think, because it makes sense that it would work again once the water slowly drained. If there isn't much water, then see if the water that is there is hot. If it's not, then it's the heating element. Checking for movement of the sprayer arm is a bit trickier, as it won't be moving while the thing is open. Though, if the first two are not the problem, there's a good chance that is. Or, of course, it could be a malfunctioning control panel giving false errors. There's really no way to test for that, unfortunately - but I don't think it's acting like that is the problem.
Sep 11, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Jan 24, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
