Question about Siemens Gigaset C595 DECT 6.0 Cordless Phone w/ Digital Answering Syst
I just set up the phone with a ATA adaptor. Now the handset keeps making a knocking sound every few minutes. How do I make the sound stop?
Both our uniden phones are displaying New CID:28 and New CID:29 and we are neither receiving or can make calls??? What does this mean?
page 26 of the user manual ( detc 6)
problem --no handsets can make or receive calls ===possible solutions
check telephone cord connected at wall socket
disconnect the base ac adaptor for a few minutes , then reconnect it
move the hand set closer to the base
the cid :26 is caller I D number 26 and so on
google www.uniden.com.au for user manuals for other models
I googled ---messages cid 26 on uniden phones disconnects phones ---and got a list of uniden sites that may have the answers you want
Sep 18, 2017 | Uniden Lands Phones
Cannot access 192.168.22.1
In order to restore your router to its factory default settings, please follow these steps:
• Ensure that the ATA is powered on (for at least 20 seconds).
• Use a paper clip or a pencil tip to depress the reset button for ten seconds and release. At this point, the reset is in progress. Do not
power off the unit at this point.
• After the ATA reboots, the default settings are now restored. This entire process takes several minutes to complete.
• Once you have reset the ATA to its default settings you will be able to access the device's web configuration using
http://192.168.22.1 with username "admin" and password "admin".
1. Connect the WAN port to your broadband router using the Ethernet cable supplied. If you would like your PC to be connected to the network through the V210P/V220, you can connect another Ethernet cable (not supplied) from your PC to the LAN Ethernet
port. This enables your PC and the ATA to share one Ethernet port on your router/switch.
2. Connect your telephone handset to the Phone port. For V220, you can connect an additional handset to Phone 2 port.
Notes: A second VoIP account is needed unless your VoIP provider supports multiple connections from the one account and both ports need to be configured
individually (even when using one account that supports multiple connections).
3. For V210P unit, connect the Line port to your PSTN wall socket.
4. Connect the AC power adaptor and press the power button to turn the ATA on. The ATA will boot up and in a few minutes, the
Power and Ethernet Lights will light up.
You can read more here:
http://www.dodo.com/top-right-navigation/support/technical-support/voip/setup-guides/netcomm-v210p-setup-guide/
Good luck
Oct 31, 2012 | NetComm V210P
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
How to connect multiple phones to voip adapter? Only line 1 is available for connection.
Have you tried using a 5 or 8 port switch to see if this will allow u to have 8 or 5 more phones available ...they do make a 25 switch if you want to add 25 phones
Sep 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Panasonic Kx th112 sceen is dead answer light blinks red
Try swapping the AC adaptor from one of the handsets with the adaptor from the base unit. That fixed my problem.
Jul 21, 2009 | Lands Phones
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Portable hand set will not hold charge longer than 10 minutes.
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps are worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Mar 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
GE model 25881 5.8 GHz dual handset phone
DON'T hold the memo key. Use the book for set up instructions. Took me about 6 times to figure this out!
Jul 16, 2008 | GE 25881EE3 Phone
My base unit has just got locked and am not able to access any keys.
unplugging it for a few ours possibly over night should reset it while your at it go ahead and take the battery out of the phone and let it set to
Feb 06, 2008 | Panasonic KX-TH112 Phone
Siemens Gigaset C595 DECT 6.0 Cordless Phone w/ Digital Answering Syst Logo
103 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
