Question about Brookstone HDMI Pocket Projector
When I turn it on, it only shows a bunch of dots. How do I fix this?
My nevi 2595 shows only touch dot and will not do anything else. If you touch it the dot moves to another area on the screen
It looks like you are in the calibration mode ... just touch every dot and after a few times it will go back to the menu ... as usual.
Dec 24, 2014 | Garmin nuvi 2595LMT 5" GPS w/Lifetime Maps...
Comes up with press dot screen nothing I do seems
Have you tried a screen calibration? Turn off the unit then press and hold the upper left of the screen as you turn it on. A dot will show up on screen and then press the dot firmly as it moves around the screen. When it is done it will say screen calibration complete.
I also assume you tried a reset by pressing the reset button or on the newer units just hold the power button while turning it on for about 15 seconds until it reboots.
Thanks for using FixYa
Sep 25, 2011 | Garmin nuvi 1450 GPS Receiver
Screen shows a bunch of "static"-- dots on screen. I hooked up a different monitor and got same result.
Likely a issue with the video card. If those dots appear as the laptop is first turning on then for sure it is hardware related. If the boot up sequence is fine but windows displays dots it is a software issue that can be resolved by updating the driver or booting into safe mode. If hardware please contact the manufacturer. -Ravi Shanghavi
Aug 18, 2010 | HP Pavilion zd8000 Notebook
Whenever i start up my xbox i dont have anything on screen but a bunch of dots that move across the screen in unison
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Jan 09, 2010 | Microsoft Xbox 360 Console
Black screen with dots but everything is fine.
this is your TV Set. it needs to be bigger and more HD than the one your using.
Sep 06, 2009 | Microsoft Xbox 360 Console
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Gaming screen
buy a disc cleaner and only use once it will work and only cost 5-10 pounds.
Oct 07, 2008 | Microsoft Xbox 360 Console
When i turn on my 360 a bunch of vertical lines appear there dotted
I had the same problem with my system until today I changed the x-clamps and it's working great.
Mar 16, 2008 | Microsoft Xbox 360 Console
Can't enter numbers
Hi try the firmware update 1st ok online from website ok texas.com
Feb 05, 2008 | Texas Instruments TI-83 Plus Calculator
Brookstone HDMI Pocket Projector Logo
126 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Jerry Kramer
Jerry Kramer
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
