Question about Bella Kitchen Appliances - Others
My Bella deep fryer stopped working and the lights are off , how can I fix ?
bigg t
  • 640 Answers
SOURCE: deep fryers
Yes you can,you need to change the regulator,gas valve and orfices.
Posted on Jun 06, 2008
SOURCE: Deep Fryer stopped working.
I had the same problem, but I fixed mine!!!! Make sure that the part with the control panel is locked in. It you just sit it in, it won't come on. You must lock it in on the side.
Posted on Jul 09, 2008
SOURCE: Deep fryer not working
May Blow Your Fuse Replace the fuse
Posted on Jul 18, 2008
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
  • 77 Answers
SOURCE: my deep fryer is leaking oil,how to fix it
Replacing the tank isn't cost effective. I am the only one I know that repairs fryer tanks. Most cannot be repaired(welded) successfully. If you got 8 years out of it..that's not bad. Time for a new one.
Tom
Posted on Aug 17, 2010
How to clean deep fryer
Hi There Best way To Clean Bella Deep Fryers Is To Use A Cleaning Product Called (Fry Clean) Its a Non Toxic Washing Liquid You Heat Up And Pour Out, Easiest And Safest Way Avaliable
Aug 01, 2014 | Bella Kitchen Appliances - Others
Nutrispin fryer oven
i have a bella nutrispin fryer oven model cg69a i lost my manual where can i get one
Mar 05, 2014 | Bella Kitchen Appliances - Others
My Bella Cusina deep fryer does not heat.I checked the electric cord and is ok.Also I cleaned the fryer.This equipment has been used for about a year and a half on once a week basis.
I'm sorry that I don't know much about home model products, only commercial brands....however your unit will have a heating element in it and maybe that's bad?
You could always go online, find the companies 800 number, call and speak with their service/warranty dept. They should be able to walk you through that process fairly easily, I would think? Good luck, Susan REO
Oct 30, 2011 | Bella Cucina 13401 Deep Fryer
The removable tank will not come out? isn't it suppose to come out?
I called customer service this morning and they said it was a misprint in the manual and that it's actually not supposed to come out.
Jan 21, 2011 | Bella Cucina 13401 Deep Fryer
My deep fryer stopped working while frying. How
id look in the right side groove and you will see a tiny microswitch that wont allow power to the element unless its sitting in the cradle I simply took the 4 screws off in the back of the heating element control and by passed it by connecting the 2 red wires and it worked so now I got to find the microswitch but at least I can use it
Dec 22, 2009 | Tefal Ultimate EZ Clean Pro Deep Fryer
Apr 08, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
157 people viewed this question
Top Bella Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Bill Boyd
richie46
Are you a Bella Kitchen Appliances - Other Expert? Answer questions, earn points and help others
