Question about Bissell Vacuums
Used bissell how do i know if parts are missing
Saw a used Bissell pro heat 7900 where do I find the tanks to fill and where is the disposal tank
    Habit-Forming:
  • Bissell Expert
  • 159 Answers
The main water tank is two staged; you put clean water in and the flexible bladder allows the machine's pickup suction to fill. This removes the need for two tanks (but it's harder to clean out the suction tank area). Just remember to clean the filters each use. There's one on the underneath of the clean water tank cap and one under the FLOW INDICATOR cap. You may need to get a User's Guide. Try calling the Consumer Care at 1-800-237-7691 Hope that helps.
Posted on Jan 30, 2016
reddevil6
  • 1673 Answers
SOURCE: Bissell Quicksteamer Powerbrush, modele 2080
There is a gasket on the cap, part #2035541 , gasket will come with the new cap.
Posted on Aug 10, 2008
SOURCE: Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Posted on Jan 14, 2009
  • 26 Answers
SOURCE: Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Posted on Dec 23, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
BissellCSR
  • 276 Answers
SOURCE: I have the Bissell heat pro 2x 8920 and the water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Posted on Jun 15, 2010
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
How do I fill the tank
Hi, it's Jeremy from Crucial Vacuum.
Attached in the link below is the owners manual for you Bissell 88920 ProHeat 2XTM. In the manual is a step-by-step set of instructions for how to remove and fill your vacuums reservoir.
http://www.bissell.com/assets/0/132/134/228/4e4eb7cf-4d35-4122-be68-8d6f346db4e5.pdf
To Remove the tank from the base of the machine lift up the tank carry handle. You can see this on page 9 of the manual
You can purchase direct your bissell pro heat replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=pro+heat&order=relevance&dir=desc
Jeremy Lerner
Aug 05, 2014 | Bissell 8920 ProHeat 2XTM Upright Vacuum
How do you put the soultion in and how do you use it
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Apr 06, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
My bissell pro heat turbo 9300 ...the bladder is not emptying so the carpets can be rinsed
There is a clog somewhere in your tank. Either in the bladder or somewhere in your tank. You can find replacement tanks here:
Proheat Parts
GoodVac.com
800-775-6586
Jan 13, 2011 | Bissell Vacuums
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does the cleaner solution go in small tank. Should the little tube be down in solution?
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
