Question about Staples Tools & Hardware - Others
Why is my staple gun shooting 2 staples at a time instead of 1? How do I fix that?
    Scholar:
  • 70 Answers
Morning Sherri,
Usually, if a tool is sending two staples out at a time, the wrong staple series is being used. Please check if the pack of staples you're using is suitable for the machine. If they are compatable, then make sure that the magazine (Where the staples go in) closes properly.
My usual analogy is: Tyres may look the same and do the same job but, you try and put a bus tyre on a bicycle - just can't do it.....
If this doesn't sort the issue out come back to me.
Regards
Alex
Leigh Co Limited
Posted on Apr 09, 2015
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
Oct 04, 2017 | Staples Tools & Hardware - Others
Powershot, heavy duty, forward action, staple & nail gun will not shoot staples
If you are referring to a Swingline powershot model 1000, you may try using the following staples for best results: True Value part # 659857 for 1/4" staples or True Value part # 660426 for 3/8" staples. You may also find these staples at Sears under the Sears part #: 1/4" is part # 74417 and 3/8" is part # 74418. I hope this helps, often times, using an incorrect staple will give you undesirable results.
Oct 07, 2012 | Tools & Hardware - Others
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
After shooting a staple the driver does not return up into the stapler.
obvious answers are 1. a burr on the striker, 2. a bent striker. 3. a trapped staple 4. a broken return spring. other than that I cant help you without seeing it.
Feb 02, 2011 | Senco 300120n Sksl Medium Wire Staple Gun...
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Every time I load my easy shot 5650 stapler they fall out the end they are supposed to shoot out...why is that ??
The way you load this staple gun is: (1) turn it upside down (2) press the unlock tabs on the rear end of the loading slide trey and pull it back (3) droup a row of staples into the slot w with the pointed end facing up, while keeping the gun upside down, push the spring loaded slide tray forward until the locking tabe engauge. (4) turn the gun rightside up (away from you), and fire it. the stape should come out normally, the rest should not fall out.
Nov 28, 2010 | Comfort LLC Arrow 5650dtc Staple Gun &...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
The door at the back of the staple gun won't close
You have too many staples in the gun. Chances are it was not shooting staples so you put more in. (Only holds 1 strip as if new from box) Check for a jam. Sometimes this keeps more staples from advancing. Please rate
Jun 05, 2009 | Arrow Fastener Co. Hd Staple Gun - T50
Tools & Hardware - Others Logo
80 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
