Question about Dryers
I replaced the element in my 80 series dryer. Now the element continues to heat without the dryer running ! Any ideas?
    Sergeant:
  • 211 Answers
Some were u got what call short to ground. It problem the motor are u got a wire touch the dryer cabin if u don't know how to check it u might won't call for service are when u put the element back in it case one of element heating coil is touching the case.
Posted on Apr 03, 2015
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Posted on Feb 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 07, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
ftw1952
  • 10319 Answers
SOURCE: I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Posted on Feb 04, 2010
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
May 20, 2014 | Kenmore 80 Series Heating Element -...
Kenmore dryer Part# 8562458 Series 80. not heating, glow bar is not getting hot.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 25, 2010 | Kenmore Dryers
Dryer rotates, but there is zero heat. Kenmore Series 80, model 0104806
First check your breakers in the power box to the house. If one the the legs is tripped, the cylinder will turn but will not heat. Next, check the thermostat switches near the heating element for continuity. If no continuity, replace them. Check heating element for continuity. If no continuity, replace.
Aug 08, 2010 | Kenmore 84052 Dryer
I have a kenmore 80 series electric dryer. The dryer is spinning but not heating. I have replaced the heating element and High limit thermostat and the dryer is still not heating
The best thing to do is a continuity check on the AC supply from the main supply through to the heating element and determine where the fault is.
Jul 08, 2010 | Dryers
Have a Series 80 electric dryer. No heat, but the blower works. Bought in 1999. Don't know where to start. Would like to do this myself. Any ideas? Thanks
Un plug the machine, check the thermal fuse, located in the rear of the machine behind the back panel. Usual it looks like white plastic with 2 wires on it. you should use a continuity meter and test the thermal fuse with the wires disconected.
If no continuity : the thermal fuse is bad and could have been caused by a blocked vent or bad operating thermostat or it just went out. you will need to replace it.
If you have continuity : you can check the heating element located on the right. remove the wires and test for continuity. If you don't have continuity the heating element is bad and you will need to replace.
There are many other thing that can cause the no heat issue but these are common problems.
Jan 13, 2010 | Kenmore 62802 Electric Dryer
My 80 series sears kenmore electric dryer runs but won't dry
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 28, 2009 | Dryers
Kenmore 80 series runs but dont blow hot air
Feb 12, 2009 | Kenmore Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
