Question about Car Audio & Video
When i connect my ipod to the aux theres no sound but wehen i put the radio on theres sound ..this just resently happend
    New Friend:
  • 29 Answers
Try buying a new aux cable
Posted on Apr 03, 2015
SOURCE: radio sound but NO cd or ipod sound
its not the radio. you have an amplified system in your vehicle and you hooked up the power antenna (blue wire from the radio) and the amp is only energized during AM/FM playback. disconnect the blue wire and connect the blue/white to the car's harness to energize the amp during ipod and cd playback
Posted on May 26, 2008
  • 17 Answers
SOURCE: THe radio doesn't recognise the AUX connection
While you may read over a million answers to this problem, try this one first:
With the KEY ON, POWER THE UNIT OFF, by pushing the volume button IN for 3 seconds.
After power is off and key is STILL ON, press and hold the volume button AGAIN for 3 FULL SECONDS. The elusive "Initial" settings should reappear at this point. press function to navigate the INITIAL SETTINGS to turn on AUX1 or AUX2, and even to set the clock...
To get out of INITIAL SETTINGS, simply press again for THREE SECONDS, or press "BAND" to "escape"...
I hope this helps.
Scott
Posted on Oct 07, 2008
SOURCE: No sound with iPod Adapter CD-IB100II in the DEH-P2900MP
on the radio and the adapter their is a spot for the cord that connects the two the ends have different colors on them it should be purple and black just make sure the colors are matched up if they are off it will still read all the info and say its playing but no sound will come out
Posted on Nov 12, 2008
SOURCE: MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Posted on Mar 01, 2009
  • 7 Answers
SOURCE: can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Posted on Jun 05, 2009
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
There is a aux in the back of my stereo will it work for my ipod? i cant get the front mini aux to work?
For this to work you will need an aux cable with RCAs and an iPod cable with receiving RCAs, or an aux cable with an iPod cable on the other end( haven't seen that one...yet). Mount it near the center console because there will be no controlling the iPod from the radio, only sound.
Sep 16, 2010 | Pioneer DEH-P680MP CD Player
Want to connect ipod, how can i do that
Its on the back of the radio. Here is the link for the part you need to convert to rca's so you can plug in a ipod.
http://cgi.ebay.com/Alpine-Ai-Net-RCA-Aux-Input-Cable-KCA-121B-for-IPOD-A1_W0QQitemZ110466314443QQcmdZViewItemQQptZOther_MP3_Player_Accessories?hash=item19b84e30cb
Apr 08, 2010 | Alpine CDA-7897 CD Player
AUX doesnt work good. when i plug in my cord to my ipod and put the cord into the head unit the volume is really low and it sounds bad. i raised the volume up on my ipod all the way and its still the same
Test the cord first , the three parts on the male should make a different tone while connected to your radio Aux, If you can find a second cord test it again if not most likely your radio is bad.
Sep 16, 2009 | Car Audio & Video
Harley Radio aux port not working?
The problem is you have a bad aux plug for repair info you can email HRmotors@aol.com- Thanks
They usualy ware after time and start making bad connections
Jun 26, 2009 | Harley Davidson 426290 AM/FM Radio
Can i connect ipod adaptor to rca output jacks?
Jun 05, 2009 | Clarion M255 AM/FM Marine CD Player
I was given an Ipod Touch for my Bday and I want to use it in my 2006 Honda Odyssey EX. The radio has an AUX/XM button but I can't locate the input for the AUX. Would you be able to tell me where the input...
There are 2 possibilities here:
Most Odysseys I've seen, have a small compartment on the left side of the third row that opens up to show a set of inputs (Audio and Video) as well as 3 headphone jacks with volume control.
WHat I did for mine was I purchased an extra long RCA audio cable on one side and a Stereo mini-plug on the other. I connected it back there where mentioned. Then I routed the cable under the rear door plastic plate and under the driver's seat, where it reappears under the center table.
Whenever I want to connect my iPod Touch, I just grab the plug, connect my iPod then raise the volume of the iPod all the way to the max, put the radio in XM/AUX and play away.
2) The second way to do this is a bit more complex, and will be the needed way if you do not have the A/V connectors in the back:
You will need to pull out the radio and the auxiliary connections should be in the back of the radio, or connected to the main radio plug.
I would recommend taking the van to an audio shop to do this installation.
Hope this helps!
May 18, 2009 | 2006 Honda Odyssey
Aux or line in
No line in or aux inputs. Installation Manual is here; http://vault.alpine-usa.com/products/documents/OM_CDA-W550.PDF Best of Luck.
Sep 27, 2007 | Alpine CDA-W550
When I plug in my Ipod to the Aux.....
I am having a smilar problem, I think the aux jack itself is messed up. I lose the sound out of the left channel, then I jiggle the connection a bit and get the sound back... Often when you can hear instruments and no voice you are hearing only a left or right track. Are you sure both the left and right is working?
Aug 23, 2006 | Aiwa CDC-MP3 CD Player
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
