Question about John Deere Garden
I have 6110 john deere it's getting fuel in the crank case what's the normal cause
  • John Deere Master
  • 2,478 Answers
Or your fuel solenoid not working. I install a fuel shut-off in line be for carb. No more problems.
Posted on Apr 04, 2015
  • Eugene Rounds Apr 04, 2015
    Dennis did you even look at the IPL for the 6110? No Carburetor
  • John Deere Master
  • 1,169 Answers
IPL indicates this engine uses a fuel injection system which is probably uses diesel fuel.
Don't know a lot about fuel injector systems but it is either a leaky injector or leaky injector pump. With my luck it probably would be the pump seals.
    Top Expert:
  • John Deere Master
  • 45,295 Answers
Sticking float in the carb
    Ray, The JD 6110 has no carburetor.
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a John Deere 2020 diesel. I can't get the fuel pump off
You need to remove the nut under the cover in front of the pump and then borrow a tool from a j.d dealership to pull the coupler off the pump,you may need the dealer to do this because they have a no lend pollicy for their special tools.Hope this helps.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: john deere tractor x585 not getting 12 volts at fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Posted on Jan 01, 2010
SOURCE: john deere L100 is not getting fuel to the engine.
Jdeer L100 fuel does not stay in fuel filter drains back to tank
Posted on Mar 22, 2012
My John Deere Z925A cranks but will not start. Is this a Solenoid or a starter problem?
If the engine cranks, then both the solenoid and starter are good. The engine is either not getting spark, not getting fuel, or the valves are out of adjustment and the engine is not getting compression.
One of those three things will be the source of your problem. Hard to say which although least likely is the compression problem. Most likely is the fuel problem.
Jan 31, 2017 | John Deere Garden
John Deere 2005 Trail Buck 650 ext fuel pump
john deere trail buck 2005 650 when accelerating before it gets to top starts cutting out pretty bad. In the high altitude it was doing that and not it does it here in MO. What causes this a weak fuel pump? Thank
Mar 10, 2014 | John Deere 2005 Trail Buck 650 EX
Fuel pump problem
I am pretty sure that your mower doesn't have a fuel pump... What kind is it? Mowers are gravity fed and pulled by the carb suction. Carb dirty or bad= no fuel flow. Check the outlet of the tank there could be a piece of trash in it or in the fuel line preventing flow. Try a new filter and make sure the correct filter is installed as it will cause those symptoms. Also if it cranks an runs like normal without you dumping gas manually in carb, then its fine. Not all filters are going to be totally filled especially the wrong ones. Half is normal. Id need more details to know give you an sure accurate answer.
Nov 09, 2013 | John Deere L100 Series
What would cause diesel in oil on a 1070 john deer
If the injector pump is driven from inside the crank case the pump could be the cause of fuel in oil. I saw this problem happen on a Ford
Sep 30, 2013 | John Deere 670 770 870 970 1070 Compact...
John deere 6715 tier 2 wont crank
a bad safety switch will shut off the solenoid most likely the one on the clutch/brake pedal
Jun 27, 2012 | Garden
How to prime a john deere 6415 after replacing fuel filters
disconnect the fuel lines after the filter and crank it. then hook the lines back up and crank it over. if its a diesel use some starting fluid and spray it into the intake to prime it.
Jul 12, 2011 | John Deere Garden
John deere tractor 1070 will not start not getting fuel to only 3 cyclinders has 4 cyclinders fuel tank full have changed fuel filter bleed the lines fuel gage is not working but was working before
The lookup at:
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
for the model 1070 harvester shows it is a 3 cylinder unit.
What I might recommend is pull off the valve cover and make sure the intake valve is moving up and down as the engine is cranking. (dont get cut up)
It sounds like a pushrod may have fallen out.
good luck.
Joe
Feb 10, 2011 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Garden Logo
116 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
