Question about Home
Water doesnt get hot unless you run the sink first then the wster on shower get boiling hot then ice cold showers a few weeks old
  • Tracy Shine
    Tracy Shine Apr 03, 2015
    is there a safety feature on the shower or the boiler that would turn the heat of
  • 1,087 Answers
So you have 2 heating elements in your hot water heater. A top and a bottom. From the sounds of it your top element has went bad however they are only about $17 a piece new and it is recommended you replace both at the same time. Thats why it takes you long run to get hot water the top water heater water is still cold and long run gets to the bottom and gives you hot water.
Posted on Apr 03, 2015
Testimonial: "Its a council flat called them out and they changed circuit board and new switch but still having problems with the shower the council want touch it"
  • Tracy Shine
    is there a safey feature that turns the hot water of if it gets to hot
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
Gainsbourgh stanza 9.5 shower is boiling and water running slowly
it could be your shower is full of lime scale if it an electric shower if so try turning off the power and take the shower front off remove the heater chamber and block off the out let pipe and pour in a kettle descaler and wait this should remove scale then rince and put back together checking for leaks .
Jan 30, 2013 | Home
Warm water in shower and cold in sink
How long has this been like this? Have you replaced any faucets, or have you installed a new water heater recently?
Jan 17, 2013 | Home
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Shower goes boiling hot then freezing
does this happen with any other fixture in your house that almost sounds like an element in a hot water heater.
or remove handle and look for an adjustment dial to temper water and adjust it
Apr 30, 2010 | Home
Hot at showers but not at sinks
Do your sinks have a hot and cold handle or just one handle. how old are the faucets. If they are very old.the first thing i would do take one faucet out and replace cartridge.
Jan 22, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Home Logo
137 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
