Question about Home
How do I get the plunger knob off to adjust the water flow?
The knob is stuck on and I can't get to the adjustment screws
  • 1027 Answers
SOURCE: telescope knob
Still not enough information, but taking a stab at it, I'll assume you mean the pinion rod that goes between the focus knobs, and engages a gear rack on the focuser. There are locations where they can be purchased, and you would need to provide the OD and pitch (teeth per radian) to match.
Try: http://www.pinionrod.com/ as a source.
Posted on Jun 13, 2008
mirran
  • 515 Answers
SOURCE: cant adjust water flow
You need to replace the printed circuit card in the machine.
Posted on Jul 12, 2008
  • 2976 Answers
SOURCE: My hot water in the shower is not as hot as from
Looking in at the screws from the shower side, first, check to see if you can feel any threads sticking out from either adjuster. Try to set them the same. Counter clockwise will give you more water from the pipe you adjust. If either of your pipes are smaller or filled with more corrosion than the sink pipes, you will have impared flow. If adjusting the valve doesn't give you the desired temperature, if you have the ball type valve, the seals need to be replaced. If you have the cartridge type valve, the cartridge needs to be replaced.
Posted on Aug 14, 2009
Adrian762
  • 425 Answers
SOURCE: How to adjust the fuel flow screw on Yamaha Gladiator,BS 26 carb
There is not enough information for me to identify your bike. Go to http://www.carlsalter.com/motorcycle-manuals.asp , and see if your model is listed, and if it is then download a manual. I have a "Genesis", but it is actually a FZ750 Yamaha. :)
Posted on Dec 31, 2009
  • 44 Answers
SOURCE: screw missing in ring that adjust varible power
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Posted on Jan 03, 2010
Will not idle
If carbureted, you need to adjust the the screw that opens and closes the flow of gas. Start with it half way open and adjust from there. Los, you will need to adjust the idle knob as well once you get fuel flowing through the carb. Good luck!
Sep 16, 2013 | Yamaha Motorcycles
Users manual for admiral atw4475xq
ATW4475XQ - Admirial Water Saver washer - Adjust Rinse cycle water level
The rinse cycle water level can be adjusted. Unplug the machines power.
You can youtube a video on how to remove the top control panel, its just 2 screws on the back of it,
phillips head. Swing the control panel up, and find something to support it so you have both hands free.
(http://www.youtube.com/watch?v=MYn0_qCFdec)
You'll see a clear plastic tube coming up from the back rear like 3/8 in diameter, to a "T"
connection. The one that goes to the left, thats the wash water level switch it connects to. The one you
can adjust, large, medium, small, from the front of the panel . The other off the T goes to the rinse
water level switch. There is not a knob to adjust it. But if you look at the bottom of the lever
mechanism/cam pickups of both switchs, you will see that they are the same. Rotate the wash load size
(knob on outside of control panel) from small to large, back to small, notice how the mechanism changes?
The rinse water level swtich acts the same way, although it is only a 2 position switch, small and
large. Once you watch the wash level mechanism move from rotating it back and forth a few times, you
should be able to see how to rotate that same mechanism on the rinse switch 1 click. It will click into
place, there are only 2 positions as I said and from the factory its in small, so once it "clicks in"
dont go any further. I did mine with a very small screw driver without removing the rinse switch.
Once you get that hidden switch turned to the other position, put it back together, fire it up and now
your rinse is the large level, all the time.
NOTE: There is a white plunger out of the end of each switch with a screw located in place. Dont mess
with the screw or that plunger. As you adjust the lever mechanism/cam this adjusts the amount of that
plunger sticking out, which changes the pressure pickup for water level.
May 17, 2012 | Admiral Washing Machines
How do you take the control panel off of a ATW4475XQ admiral washer
Pulled this together from two other posts & added some details that I found as I performed the fix successfully!
Mar 17, 2012 | Washing Machines
I have an admiral washer atw4475xq can you adjust the water level on the rinse cycle
Pulled this together from a couple of Solutions & added some helpful tips I found as I successfully changed the rinse cycle water level!
Nov 14, 2011 | Admiral AW22 Top Load Washer
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
How to adjust rocker shaft on discovery td5
There are adjustment screws on the rockets according to RAVE.
The procedure is as follows:
1) Rotate the engine clockwise until No 1 injector lobe is at full lift.
2) Rotate rocker adjusting screw clockwise until the injector plunger is felt to bottom out.
3) Rotate rocket adjusting screw anti-clockwise one complete turn to give plunger the required bump clearance and tighten rocker arm adjusting screw locknut to 16Nm. Ensure the screw does not turn as the locknut is tightened.
4) Carry out the procedure for the remaining 4 rocker arms.
5) After completion of rocker arm adjustment slowly rotate engine clockwise 2 complete turns by hand to ensure that no injectors are bottoming out on their plungers.
Apr 08, 2009 | 2003 Land Rover Discovery
I have a 425 gas tankless water heater. In 3 years in the winter (and sometimes warmer weather) I have never gotten a hot shower. The water starts out warm, and in the middle of the shower changes to...
Is it a bosch.What is the exact model number.I have one and i love it once you get it set.It seems that there are two flame levels low water flow and high water flow.If your shower has a water saving restricter in it it may not flow enough to let the flame get too high.So i would remove it.If there is a knob on the front turn it all the way clockwise and try it.There is also a screw on the inside that you can adjust the low water flow flame , it the brass one with a locking screw on it.Your manual should show it.If you need to adjust it turn on your shower and go check the flame and use that screw to increase the flame.Hope this helps and let me know how that works
Nov 29, 2008 | Heating & Cooling
Cant adjust water flow
Dec 30, 2007 | Saeco Vienna Espresso Machine
Home Logo
73 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
