Garden Logo
j
johnny pienaar Posted on Apr 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a JD 1030. The PTO shaft turns but has no power. Any idea what the problem may be? What type of clutch does it have. Any input is appreciated.
Gary Hill
Level 2:
Sergeant:
  • Expert 462 Answers
  • Posted on Apr 23, 2015
Gary Hill
Expert
Level 2:
Sergeant:
Answers
462
Questions
Helped
129583
Points
926
Clutches available online just type john deere 1030 clutches
2answers
I have a Toro LX 500 Lawn tractor the pto clutch will not engage, I have 13 volt at the plug for the clutch , so ordered and installed new clutch... Still will not engage checked volts again had 9.3
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 21, 2015 • Toro Garden
THE BLADE DOES NOT ENGAGE WHEN I PULL OUT THE KNOB THAT IS SUPPOSE TO ENGAGE THE MOWER BLADE
"I have an Electric Clutch and my Blades will not engage when I operate the PTO switch."
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Is the deck belt intact?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared?
  • When you pull the PTO switch does the clutch make a "click"?
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. Do not confuse this click with the clutch click.
Leave the Key in the Run position, cycle your PTO Switch on and off. You will hear a click. This click will be twice as loud as the fuel switch click. This louder click is the Clutch engaging. If you do not hear this click, the PTO switch may be bad or the Clutch may be bad. This is assuming your battery is good and fully charged and that your Key Switch is functioning correctly.
PTO Clutch will Not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
  • It does not give the air gap.
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
Only after i got stuck in mud did blades on snapper lt 200 42 rider so working belts are tight must be sensor insert seat went out or went bad
Blades would not turn after I got stuck in mud. Electric clutch?
  • There is a drive key between the clutch and the shaft. Has this key been sheared? It's possible the clutch was burnt out during the mud incidence.
PTO Clutch will not engage or stay engaged.
Blades won't engage after got stuck in mud electronic pull on blade engagement
Blades would not turn after I got stuck in mud. Electric clutch.
  • When you pull the PTO switch does the clutch make a "click"? It's possible the clutch was burnt out during the mud incidence.
Apr 10, 2015 • Garden
1helpful
Pull switch on blades but they won't engage worked fine until i got stuck in some mud now won't engage
Why does the pto on my not turn on?
Electric clutch may not be getting enough power. Check fuse. It may be getting power that is not sufficent from low battery. Check water level in battery, check power by turning lights on and cranking motor. If lights go very low then battery is suspect. If my JD battery gets very low it has to be charged with external charger as the JD charger cannot bring very low battery up and drive clutch too.
1helpful
2answers
I have a JD 1070 4 wh dr, when running a brush hog on the back pto, what would make the pto shaft slow down under a load when cutting light brush, funny smell. Checked all oil levels.
Reading on line, I see your tractor has a PTO clutch. It must be slipping. It either needs adjusted or replaced. A slipping clutch disc will make a bad smell.
Top Garden Experts
Jay Finke
Jay Finke
john h
