Question about Moen T4111 Kingsley Moentrol Shower Valve with Built-in Three Function Transfer Valve Trim Chrome
How do I adjust the shutoff valves on a Moen t4111?
I have an airlock in a moen solidad 87559 kitchen faucet. Does anyone know how to fix it?
The most likely cause is the shutoff valve under the sink has lost part of the rubber washer and has traveled into the faucet. Faucets don't get airlocks
Apr 27, 2016 | Moen Plumbing
Moen Universal Fill Valve Model M5350 problems
Some kind of crud may have goten into the fill line during installation and is blocking shutoff. The new fill valve could be defective. Something may be preventing the float from stopping the flow. The flapper may be allowing slight leakage, preventing the fill valve from shutting off and staying off. The "overflow tube" actually is the fill tube; the tank fills from the bottom up.
Feb 01, 2014 | Home
We just installed a Moen Banbury single handle faucet, and we have very little water pressue. The pressure in the rest of the house is fine, and we cleaned out the aireator filter. Any ideas?
Yes, Pull the faucet and look for particluate matter in the water passageways. Also check your shutoff valves, they have washers that fail, and then break up with you shut them off for faucet replacement, and little pieces get flushed into your new faucet....Kind of a common issue.
Oct 05, 2010 | Moen Plumbing
Sensitive Temp adjustment through shower.
Pull the trim off of the valve and you will see a 1 inch diameter flat screw, unscrew that and clean it out and try it again. If rinsing it doesn't work you may need to replace it. It is called a balancing caulk.
Apr 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Need to replace a moen tub-shower valve without tearing down a wall. Can you help? Where can I get the valve?
If you remove the handle and the fasia plate you'll see the valve in the center (make sure to turn off the supply valves first. These are located at 3:00 and 9:00 beside the valve. Then the whole assembly unscrews from the center with a large adjustable wrench or a pair of channelock pliers.
Feb 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
My(installed today) moen single handle shower valve (82910CBN) is only producing cold OR hot water. It is not mixing. What should I do to fix this?
if u still have instructions it will explain how to adjust the water -in the handle are a red and blue plastic tabs that are adjustable pull back and turn to adjust --this is the anti-scold--till u are satisfied
Nov 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
Hot water not working - no shutoff valve in line, and hotwater works at sink.
From what you've described, it's got to be a block between the main supply line and the shower head.
If you have never used this shower after its installation, it's possible that the temperature limit stop is set too low.
Otherwise, either the hot water valve or the balance spool need maintenance. The instructions on pages 4-6 of the link below should be helpful for correcting the problem.
http://www.moen.com/shared/pdf/instruction_sheets/INS162E.pdf
Sep 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
Jul 17, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Moen T4111 Kingsley Moentrol Shower Valve with Built-in Three Function Transfer Valve Trim Chrome Logo
405 people viewed this question
Top Moen Hardware & Accessories Experts
Steve Mason
Tom Chichester
Are you a Moen Hardware and Accessory Expert? Answer questions, earn points and help others
