DUNHAM-BUSH chiller compressor refused to start
Here is the model number of the chiller:AFHX2968 - ESR The compressor model is HISC 1813 LA 35 BQ1C, RLA 250.0, LRA 980.0 When the compressor status key is pressed, it comes up with the following; Comp 1 ... Amps ... 000A FLA1 ... 143A Target ... 000.0% Capacity ... 000.0% Status ... OFF On normal operation, comp 1 will display 300 and start counting down. As soon as it gets to 000 the compressor will pick. As it is now, comp 1 is not displaying any figure against it. Please help. Thank you.
SOURCE: resetting the imaging unit
How do you reset the imaging unit?
Posted on Jun 05, 2008
  • 5 Answers
SOURCE: error code E000051-000
E000051-000 is not a waste toner full error code thats E000015. This error code refers to the horizontal registration sensor not reaching home position or is not detected when the assembly is commanded to move. The sensors function is to determine the edge of the sheet of paper in the front to rear direction to determine the write position on the drum. It is not somthing you can fix and would require a tech. Possible sources of the error are, DC controller, horizontal registration sensor or actuator, or the horizontal registration motor. Based on experiance the motor is either stuck or burned out so the sensor does not move at start up
Posted on Jun 07, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
SOURCE: 9 inch screen---model " RD0946 T102
hold the channel up and the volume up button together for 2 seconds and it will go off.
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
Midwall unit works /cools for a while and switch off by itself,and comes on when switched on again with a remote, what is the fault with it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 11, 2017 | Bush Televison & Video
L have a bush tv l need to know the maker to set up remote control?
dunham-bush is an industry leader in the manufacture of heating, refrigeration, and air conditioning equipment for commercial, industrial, and institutional applications.
Feb 16, 2015 | Bush Televison & Video
York chiller YDAJ model chiller compressor trips in low oil pressure after running for sometime. To solve it i changed the oil & the oil transducer but still tripping what can i do
You could be light on charge or the oil pump is failing. There may be a delay setting that is set incorrectly. I see that with several 507 systems.
Nov 29, 2014 | Air Tools & Compressors
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
This compressor is in my aquarium water chiller. When I plug in the chiller, The compressor starts then goes off. a few seconds later it starts again then goes off. It continues to do this. I have changed...
The Freon is probably a bit low. When the compressor draws from the low side the extreme low pressure trips the low pressure switch, shutting down the compressor. With compressor off the pressure equalizes the low pressure switch opens and the compressor switches on. murf427
Aug 02, 2012 | Panasonic QA125K29CAU6 Refrig...
I need a wiring diagram for an old westinghouse starter model number 3462d31. It is for a 750 ton chiller model number cv76-11088
E-mail me @ Bobicehouse58@yahoo.com and I will send you what I have.
Make and Model of Chiller will be helpful.
May 05, 2011 | Heating & Cooling
Honywell whine chiller model 88058 not working
Hello friend, i had the same problem and it was solved replacing largest capacitors on board, they are 2 x 120uF(120V). You must to check that both original capacitors be damaged, you can to see it if they are inflated on the top
Jul 23, 2010 | Honeywell Consumer Products Model...
Part no. expansion valve of Air cooled chiller
On a chiller with semi hermetic compressors can have different types of thermostatic expansion valves for metering. As far as a number, you will have to go to the evaporator to look at the tx valve and get the numbers. It may be a single ported, double ported, be externally equalized or not. You have to get the copper line sizes in and out also if you are planning to change the valve out. The valve will also have the type of freon the system uses if for some reason the data plate is worn off. That's the place to always find out is the expansion valve. If you need information other then what I have given you, contact me and I will help you.
Sincerely,
Shastalaker7
Mar 15, 2010 | Heating & Cooling
35 people viewed this question
k24674
