Question about Optics
My remote will not turn on even after I replaced the batteries.
Why are no codes or automatic search with audio sonic remote not working?
Try replacing the remote battery. Sometimes a weak battery will do this
Sep 02, 2014 | Televison & Video
Comcast remote dead even after replaced batteries
Comcast does not charge to replace a faulty remote. Take the remote a Comcast office and they will exchange it. Or call them to send a replacement to your home.
Feb 05, 2014 | Comcast XFINITY
Cobra microtalk frs120 won't turn on. Has sat for an extended period; there was a bit of dried battery acid in the battery compartment of both radios. One radio works, but even after replacing th
Sometimes that highly corrosive battery acid gets on the boards and trashes them. I have lost remotes like that and now remove the batteries on those units I do not use often - remotes are expensive!
And if it happens to an expensive piece of equipment, that really bites.
Sep 04, 2017 | Cobra Radio Communications
I've gone through 3 remotes on my Vizio XVT553SV 55 in. LCD TV. The first one that came with the TV in the box quit working so I called and ordered a replacement. During the meantime, I went and bought a...
Ur universal remote have codes problems,low in batteries or replacement batteries have problems with codes.Re enter the codes again,for ur tv model.
Dec 09, 2010 | Vizio XVT553SV 55 in. LCD TV
I have the Hunter remote control fan model UC7848. The remote has stopped working, although the light does come on when the battery was replaced. There doesn't seem to be another way to turn the fan on. ...
have you sanded the terminals off on the battery contacts in the battery compartment in the remote,even new batteries at 3 volts between the 2 batteries cannot pass alll the signals if the tabs of the battery are corroded,i know ,you will say,they look shiny,but any glossy corrosion will inhibit battery voltage,use a nail file board lightly
Jul 28, 2010 | Hunter 52" Ceiling Fan With Light And...
Does any body know how to reset the ML350 alarm??....The remote control doesn't work after i replaced a new battery to the remote control. I couldn't even use the remote to lock/unlock the car. I was
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 18, 2009 | 2007 Mercedes-Benz ML350
Replaced batteries in Harmony 670. Does not work shows "Safe Mode
Update the firmware:
- Launch the software. - Connect the remote. - Click "Downloads" - Click "Firmware." - Update the remote.
That will get the remote out of safe mode.
Mar 29, 2009 | Logitech Harmony 670 LCD Remote Control
TV Remote control
my remote control quite working - I have replaced batteries, but it still will not even turn on the tv.
Oct 12, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
Optics Logo
322 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
