Question about Samsung Televison & Video
I have a samsung ln55c630k1fxza sqv1 has audio ,but very dim picture what can it be
  • 36 Answers
Switch on tv and go into menu, then check levels such as picture, brightness, if this is low change it to higher setting, it can happen if some one sat on the remote and caused setting to change. if this does not work with levels set to highest then there is some other issue with the led screen and needs checking by a technician.
I hope this was useful.
Posted on Apr 05, 2015
My Samsung LNS3251D has audio but no picture, why and can it be fixed
Here's a simple way to find the cause. With the TV on shine a flashlight on the screen. 1) If you see a dim picture then the back light circuits are bad. 2) if you do not see a picture , the T-con board is bad. You can get parts here and easily fix it yourself. TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 22, 2016 | Samsung Televison & Video
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
LN55C650L1FXZC no picture
Dim the lights in the room, turn on the set and shine a bright flash light on the screen. Do you see a faint picture on the screen?
Apr 07, 2013 | Samsung Touch of Color LN55C650L1FXZA...
My samsung turns on, audio is okay but black screen
dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture?
Mar 28, 2013 | Samsung LN52B750 52 in. LCD TV
Black Screen
There are several things that could cause this. You could have a faulty backlight inverter(s), faulty 24V output from the power supply, failing backlight bulb(s), high voltage arcing from the inverter outputs, or a fault with the main board. I would recommend a diagnosis
Jan 15, 2013 | Samsung LN55C630K1FXZA 55 IN LCD HDTV...
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung lcd 550 overheating? picture tube shuts down, but audio remains
sounds like it. if it overheats, the picture by protection, dims down and soon it'll shut off. i would check with the warranty and check it out.
Oct 17, 2009 | Televison & Video
LCD TV
I had a problem with a Samsung 46 inch LCD and it had audio and dim light but no picture and found out that the logic board toward the top (inside tv) was bad and was no longer available and the only way to fix it was to get the entire display panel (the logic board came with it) It was not costwise to repair. Hope this helps.
Dec 28, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
