Question about Nikon Coolpix S6500 16 Megapixel Digital Camera, Red - Bundle - with 16GB SDHC Memory Card, Camera Case
My lense wont open
Bought new battery charged for over 3 hrs and still won't open
Bought a new battery pack (jensen brand) for panasonic 5.8GHz gigarange supreme KX-TG6500 2Line cordless phone and it wont charge.
check that you got the right make of battery for the charger
some phones use a nicad battery and others use a lit ion battery
2 different recharegable batteries -- 2 different chargers required
Nov 29, 2016 | Panasonic Lands Phones
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
Motorola triumph won't charge when plugged in
I tried everything, bought 3 new batteries, 4 new chargers and everytime about a day goes by and the phone dies in less then 3 hrs and stays dead...tried connecting to usb, tried removing the batter and still dead...finally followed the steps on the website: https://motorola-global-portal.custhelp.com/app/answers/prod_detail/a_id/83322/p/30,6720,8064 first I held down the power and lower volume buttons for 10 sec. and no luck, removed the sd card followed by downloading the manager and motocast from the website above and finally...looks like the charge light finally turned back on...Finally guess this is what it needs with all the downloads and memory used i need to keep it up to date....I guess...hope this helps others...i was ready to tear this phone apart and just buy a new one...just saved some $$
Jul 27, 2012 | Motorola Mobility Triumph WX435 Cellular...
Just bought a new drill and battery not holding a charge
Batteries sometimes get like yours, after a full charge they last only a couple minutes on the tool. It's usually because of a bad cell in the battery. The only fix is to replace the battery. If you just bought it, take it back for an exchange of the battery or whole tool kit. If the retailer you bought it from won't exchange it contact the company it came from to find out how to get the battery replaced under their warranty.
Mar 01, 2012 | Drills
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
My asus notebook won't charge i just bought last five days ago, and now it won't charge.. i tried to remove the battery and attach the adapter, but it still doesn't open..
if it wont charge it most likely has a bad battery...if you just bought it, I would suggest returning it for a replacement. Make the vendor or manufacturer make good on their product.
May 12, 2011 | ASUS Eee 4G Notebook
I bought a Samsung Monte mobile 3 months ago. Suddenly it has developed problems. The fully charged battery suddenly drains within 2 hours. When I try to access the messages it displays "messages...
just update the software and replace the battery(if its in warrranty period) from ne service centre..
charge the new battery 4 six hrs nd den 4 second time charging let it b empty...do the same for 2-3 charging period den d battery life will b enhanced
Sep 21, 2010 | Cell Phones
When i open the game sharing my psp wont charge
There is no problem with your battery. The PSP battery life is only around 4-6 hours of straight gameplay.
Apr 18, 2010 | Sony PlayStation Portable (PSP) Console
Latitude L400 new battery not working?
u should charge new batt for about 6 hrs and then 2 to 3 hrs
Dec 20, 2008 | Dell Latitude L400 Notebook
Nikon Coolpix S6500 16 Megapixel Digital Camera, Red - Bundle - with 16GB SDHC Memory Card, Camera Case Logo
111 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
