Question about John Deere L100 Series
HOW DO YOU CHANGE STEERING BUSHINGS, STEERING GEARS AND ADJUSTABLE DRAG LINKS ON DEERE L120 MOWER
NEED COMPLETE STEPS OF OLD PARTS REMOVAL AND PUT BACK. THANK YOU SO MUCH.
  • John Deere Master
  • 2,478 Answers
Go to greenpartsstore.com and click on front bearing update
Posted on Apr 18, 2015
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
nova2nv
  • 197 Answers
SOURCE: JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Posted on May 05, 2010
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
jyackle5
  • 8197 Answers
SOURCE: I need a routing diagram for belt routing on L120
For belt routing please go to link below.
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
Good Luck and please rate 4 thumbs up for free answer
Posted on Jun 13, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
My reverse won't work
Donna, there could be an issue in the transaxle/gear box take it into a good small engine repair shop and have them diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
John deere riding mower l120 has no reverse
John Deere SX 85 will not go into reverse or move backwards
Riding Mower Will Not Go In Reverse Quick Fix
Jun 12, 2016 | John Deere Garden
Front end out of alignment how do i fix
Paul it appears your machines steering components are not adjustable, as normal tie rods are. So that means you have to replace steering parts that are worn or try and repair bent steering parts. You could have your steering links made adjustable at a machine shop. below is your manual,
press the helpful button.
http://www.homedepot.com/catalog/pdfimages/fd/fd904936-46bd-471e-9536-7c3ca3698e81.pdf
Jan 30, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Are there adjustable drag links for john deere d140 ?
Yes there are. Amazon has them. They are about $26 ea.
JOHN DEERE GY21251 Right Hand Steering Drag Link (Adjustable). Replaces GY20771, Fits LA100 & X100 Series Riders. Replaces NON-Adjustable Drag Links. Replaces: JOHN DEEREGY20771 JOHN DEEREGY21251
The Left and Right are separate products.
Jun 25, 2014 | John Deere 22HP VTwin 48" Riding Mower
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
How do you adjust the steering toe on a L130 lawn mower?
The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | John Deere 22HP VTwin 48" Riding Mower
John Deere L120 appears to run out of gas
This is the most common problem with the L120 I'm told. The pin hole in the gas cap needs cleaning (top and underneath as well). I have replaced mine twice already and have only 140 hrs. on it. Starts right up after cleaning. (My symptoms were identical to yours)
Mar 22, 2009 | Briggs & Stratton Garden
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 | Garden
John Deere L100 Series Logo
369 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
