Question about Garden
Hi I have a Briggs and Stratton lawnmower that I have given new oil spark plug and is full of petrol and it starts once an then it coughs an dies and won't start again and I don't no what to do
    Top Expert:
  • Garden Master
  • 12,957 Answers
The main jet is clogged and petrol is not reaching the carburetor properly other than thru the choke circuit which is why it starts and then abruptly stops.
Remove the gas reservoir by removing the nut on the bottom of same. With a very thin wire clear the orifice that is in that nut and also spray some carb cleaner on the inside of the tube that descends into the gas reservoir. Reassemble, install fresh gas and start motor.
Posted on Apr 03, 2015
  • 9,587 Answers
Clean the carburetor and make sure the air filter is not wet or plugged
bobjrdns
  • 84 Answers
SOURCE: will not start, briggs & stratton 3.75
put a small amount of gas in carb from top and try it. if still not starting make shure choke is in closed position . check the safty switch handle . you do have spark/ and gas
Posted on Oct 19, 2008
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
hunter19_46m
  • 7482 Answers
SOURCE: mountfield petrol mower HP470 problem with
Sometimes you can get by with priming the carburetor a few times or spraying starting fluid into the carburetor, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
rycgl
  • 1545 Answers
SOURCE: HI there, I got
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Posted on Jun 05, 2011
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Which way do I tilt my efco lawnmower to clean without mixing oil and petrol it is model LR53TBX ?
You;re usually safe if you tilt it so that the cylinder (spark plug) is kept at the highest point.
Mar 08, 2015 | Garden
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
Mower coughs and splutters starts briefly then dies
remove the gas and replace with new gas...take the carb apart drop the bopwl and clean out spray all the holes inside carb with carb cleaner and use a pin needle to prod all the small orifices to clear em....pull the plug and clean it check the oil level...spray off the grease ***** on the kill switch on the side of the motor block... be sure the blade isnt bent or loose...try it you'll like it!!
If it pulls your arm out of socket...pull off the recoil housing and rcheck the keyway shaft key for being broken or worn....remove the flywheel to replace it by removing the 3/4 " nut and tapping the flywheel gently while pulling flywheel upwards or use a puller, once off take the key to local hardware store and replace it for 50 cents...reinstall....start it up.....you'll like it I guarantee it!!!
Apr 29, 2011 | Briggs & Stratton Briggs Stratton...
Hi, i just swapped my elec flymo for a briggs and stratton 35 lawn mower, however when ever i start it it coughs and splutters and wont run for more then 30 secs and is also spitting out oil from exhaust....
if the motor has been on its side the oil has runs out thru the muffler and air filter. briggs are famous for doing that. let it sit overnight and remove the air cleaner and you see is fill of oil. next day take the spark plug and clean it and check the gap then put it back, take carburator cleaner and spray some inside the carburator, check the oil level and start.if it wont start then is time to clean carburator. the air filter if is wet in oil and is the dry type. get a new one.
Feb 08, 2011 | Briggs & Stratton Garden
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I hev a briggs & Stratton 5.25hp lawnmower and
I would need the engine numbers to tell ya what to do for sure. It sounds like the engine is too full on oil. Check oil levels carefully.That engine capacity is only 1 pint/16 to 20 oz's ALSO you friend may have cleaned under your deck and turned the mower with the aircleaner DOWN. That causes oil to flow from the crankcase into the air cleaner and muffler.That aircleaner is a dry paper and should not have any oil on it, If this is the case then the oil accumulated in the muffler will burn off in time. Oil soaked paper aircleaners will cause this engine not to start.IT CANT BREATH
Oct 21, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
