Question about Water Water Heaters
My boiler dosent come on i have no hot water but when i turn the heating on boiler works but still no hot water what should i do
    Novelist:
  • 170 Answers
IF you have a boiler with domestic hot water coil----it is controlled by the aquastat (AQS)---this usually is a 5" x 8" grey box mounted on the boiler---may be inside the cabinet----this controls the hot water when needed----with this type system the boiler is usually always on-heated----it operates by the standing temperature set---140 to 160 degree F (+or-)---when you turn the hot faucet on the water is already hot coming out of the coil---as the temp drops do to the cold water entering---the AQS senses the temp change and turn on the boiler to heat up (fire) for the hot water demand--- if this doesn't do this the AQS is faulty or needs readjustment----now another issue is that if this has been serviced/repaired and the AQS replaced but not with the correct AQS it will not function correctly for that system----now there are exotic boilers (Baxi is one name) that have electronic controls that do the same thing but no standing temp---only operates on demand (has no large volume of water--system only hold
+or- 1 to 2gal if that) with reheating its own water via heat exchanger to generate domestic how water---this is the best I can come with do to the limited info provided---good luck--- Happy Rabbit
Posted on Apr 03, 2015
    Sergeant:
  • 272 Answers
Hot water is gravity fed through your pipes. When you turn the faucet on the water will flow through the pipes. If your hot water heater is natural gas driven relight the pilot. Same if oil fueled. If electrical, check fuse to see if it has blown or the circuit breaker has tripped. If either has tripped, replace it and if it blows again the heater has a serious failure, you might need to buy a new one. If pilot won't light on gas unit, try relighting after 5 minutes, could be a bad thermocouple.
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
Water Heaters Logo
184 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
