Question about Amana NFW7300WW - 3.5 Cu. Ft. Doe, 6 Cycles, 1100 Rpm, 3 Temp, White Door, Ada Compliant On 10" Pedestal - Washer, Color - White
Anyone have a block diagram for plugging the wiring harness into the control module?
    Genius:
  • Amana Master
  • 1,585 Answers
Surely its a block connector
Posted on Apr 03, 2015
    Sergeant:
  • 272 Answers
Look for the same type of connector on the control module and the connector on the harness.
Hi i have a 2006 vw golf that is coming up with Cannot communicate with the tcm now i have replaced the tcm and its still saying the same thing
Time to diagnose properly by checking the wiring harness. Get a wiring diagram and troubleshooting instructions. You've already spent far more replacing a perfectly good module than it would have cost to buy a year's worth of alldatadiy.com
Aug 07, 2017 | Cars & Trucks
2001 windstar wiper fuse location?
Wiper relays (2) on/off relay an speed relay , location battery junction box . Look at the wiring diagram here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine . System click body & accessories , subsystem click wipers/washers . Click the search button , then the blue link . After viewing the wiring diagram for the wipers , Change systems to electrical distribution , then click junction block . Then the search button an first blue link . Shows the relay position . The wiper switch is a input to the front electronic control module . The relays are also controlled by the electronic control module . Probably has code set in the module . You would need a factory scan tool to check this .
Jun 24, 2017 | Cars & Trucks
I need a engine wiring diagram for volkswagen polo sedan 1.6 year 2006. can anyone help please. My harness from control module to engine is faulty
old school check spark fuel or compression
what actually wrong with the polo
closest i could find
Vehicle electrics in Polo Model Year 2002 - Volkspage
www.volkspage.net/technik/ssp/ssp/SSP_265_d1.pdf
auto electricians subscribe to sites that have all that information
https://www.car-manuals.info/vw/
ecu to engine loom fault is very unusual
save time and money
ring a VW wrecker and ask for a used engine bay harness out of a similar polo
Feb 17, 2017 | Volkswagen Cars & Trucks
How many wire harness clips connect to module besides the antenna
Engine Control Module Wiring Harness Replacement - 1.4 L ...
workshop-manuals.com/.../repair.../engine_control_module_wiring_harn...
3. Unclip the 3 wiring harness clips (1, 2) from the engine control module wiring harness brackets. ... Disconnect the wiring harness connection adapter plug (4).
Engine Control Module Wiring Harness Replacement - 1.6 L ...
5. If equipped, disconnect the engine oil level sensor wiring harness plug (7). ... 10. Unclip the 2 wiring harness clips (2, 6) from the wiring harness brackets.
How to fix wires that break out of plug clips on a wire harness
Dec 01, 2015 | Cars & Trucks
Is the EEC-IV module the correct control module for my truck?
Yes, I'm pretty sure an '87 model would be EEC-IV. It was an emissions control system, not a module, and Ford went through the previous generations (EEC-I to EEC-III) during the early '80's with all types of barely-working contraptions.
Just look on the VECI label (Vehicle Emissions Control Information) under the hood. It will tell if it is EEC-IV. If your wiring diagram is for a 1987 model, then you are on the right track. It may be difficult to find an illustration of the ground points. Those are usually only in the Factory Service Manual. And neither Chilton nor Haynes will reproduce that portion of the wiring diagrams. Alldata probably would have it, but that is a subscription service.
Jul 06, 2015 | 1987 Ford Ranger
Defrost keeps popping fuse 11 in fuse box making a/c clutch not to work and 4x4 silenoid
I would suspect a faulty A/C clutch. However, after looking at a wiring diagram, the only thing the A/C system and 4WD system have in common is the powertrain control module. Take a very close look at the wiring harness between the fuse block under the hood and powertrain control module for corrosion or damage.
Jun 17, 2014 | 2007 Ford F-150 Regular
I have 2010 Ford Taurus SHO seats. I believe they are 8 or 10 way memory seats. Trying to retrofit for a street rod. Have a few wiring diagrams but not enough. Can't get power to any motors yet. Numb
Problem Solved !!! I traced every wire, Bought manuals, Ended up buying a passenger seat wiring harness and removed driver memory control module plus harness. Installed new passenger harness and it works great ! You need VIN# when ordering part, Order number is slightly different then number on wire harness but when it came in numbers matched. AU5T 14D230 J4CP7
Nov 15, 2013 | 2010 Ford Taurus SHO
I have a 94' buick century special 4 cyl. I need
Generally speaking, the module is mounted on the side of the block and the coils are mounted to the module. You can remove the entire assembly and then swap the coils over to the new module.
There should be a wiring harness plugged into the end of the module.
May 04, 2013 | Cars & Trucks
Control Module WMA34
If my memory serves me well, the plugs/wires will only fit the correct spots on the module, and I believe there is a "jumper" on the original module, make sure you remove and install in the new module..Good Luck
RMK
Retired GE Technican
May 19, 2009 | Washing Machines
Amana NFW7300WW - 3.5 Cu. Ft. Doe, 6 Cycles, 1100 Rpm, 3 Temp, White Door, Ada Compliant On 10" Pedestal - Washer, Color - White Logo
32 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
