The machine is not keeping the water in its letting it out
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Could b the pressour switch
Posted on Apr 03, 2015
    Sergeant:
  • 272 Answers
Something could be blocking the solenoid valve that allows water to drain. You need to get into the guts and disconnect the hose.
How to descale?
Make a mixture of half white vinegar and half water (preferably soft water) 6 to 8 oz and run it through your machine. Let It run part way through with a new filter in place, then shut off the machine and let it sit for a while. The vinegar is dissolving the lime scale. Keep starting and stopping until you have run all the mixture through. Next, run at least 2 full pots of fresh water through to wash out the vinegar.
Dec 19, 2014 | Miele CVA2660 Stainless Steel Coffee Maker
Tip
The secret how to keep your espresso machine for years
Its like anything in life you got to take care of it cleaning it and the most important decalfication hard water residue kill espresso machine its a big invesrment some cost over 2000 dollard even the less expensive machine can last you a long time use producT to remove hard water residue fill your water tank add the decalsifier start the machine if you got a steam wan open the valve let the water out for 20 second turn the machine off for 15 minute let the decalsifier work and repeat the step 1 untill your water empty after fill the water tank and rinse evething very good dont forget decalsifier is acid so rince the water tank very good the harder your water level is the more often you need to do it 1 decal every 150 liter of water or every 2 to 3 mouth do that and its gonna last you 10 time longer
on Mar 27, 2015 | Coffee Makers & Espresso Machines
Whirlpool dishwasher 6th sense, F9 flashing inthe indicator box, what does this mean?
based off what you described i know exactly what is wrong, the water inlet valve is stuck open, this is a small valve that opens to let water into the machine however it should close again when there is no power to it, if it keeps letting water in with the power off the valve is jammed open and you will need to replace it, should be a rather cheap job
Oct 03, 2014 | Whirlpool Dishwashers
The water keep flowing out when it is on. Why?
This is what we call a syphone effect //locate the drain hose at the back of the machine and lift it up it is more than likely laying too low to the ground the hose should come out the machine and up about half way to the top of the machine then into the drain out let set hose like this and you shpuld have no more free flow of water
Dec 29, 2009 | Thomson Washing Machines
I let the water tank run empty by accident and now the machine keeps making a loud cracking/clicking sound which is intermittent whlist it is warming up. Have I done permanent damage?
It is possible that the elements got damaged, but try this fill tank let machine cool about 2 hours, then turn on and open the hot water valve and run about half the tank through, then descale machine.
Nov 09, 2009 | Gaggia Baby Espresso Machine
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
My He3 begins to fill the drum with water (very slowly) after the cycle is done, I have to turn off the hose valves after the cycle to keep this from happening. Any ideas what is letting the water back...
sounds like you have a bad water valve..if water is come in try to unplug the washer if water stop you have a bad control if it keep filling you have a bad water valve
Sep 20, 2009 | Washing Machines
My saeco s-class incanto sirius machine keeps say replace water filter & ventilate even after I replaced filter
Sounds to me that water is not getting to the pump. Try charging the water filter before using by letting it sit in some water for about 5 mins.
Jul 23, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Hoover 200m, keeps letting water in, will not advange to wash cyc
Your outlet hose is too low at the back of the machine tie the hose at about the level as your inlet hose eg to where your inlet hoses are festened and then let the remainder of the hose go to your outlet as usual.that should work Kind Regards Stefan.
Jul 08, 2009 | Hoover HTC243 Top Load Washer
Aw850 washing machine
Hi, Is the water clean or dirty? If it is clean then your water valve in side the machine is letting by and will need replacing. If it is dirty water then it is coming in from the sink trap if it is connected by this method, Or it is to far down the stand pipe and is coming back in via it.
Let me know....
Jan 26, 2009 | Tricity Bendix AW850W Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
