Question about Admiral Washing Machines
How do I reset washer it is stuck in fill mode but wont do any thing else it sits and hums
    Genius:
  • Admiral Master
  • 1,585 Answers
Check pressour switch
Posted on Apr 03, 2015
    Sergeant:
  • 272 Answers
Might be a bad motor on the control unit. Move the knob slightly and see if unit begins to work.
  • 23 Answers
SOURCE: frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
Posted on Nov 04, 2008
  • 1214 Answers
SOURCE: its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Posted on Jan 15, 2009
kachbibi1
  • 979 Answers
SOURCE: WHDSR315DDWW, Fills then just sits there and hums.
Push down on the agitator. You may have to hold the activating button in with the lid up so you can do this. Press down firmly on the agitator and it should start rotating. If it does, you need to have it replaced. If it doesn't, then let the store know and they should take care of it. You should not put any money into since it is new. Anything you do from this point will cost you some money to fix.
Posted on Feb 07, 2009
SOURCE: Kenmore Commercial washer 110.20172001
Sounds like motor is bad. See if you can find the 2 main wire leads on the motor and hook up directly to see if you can get it to work.
Posted on Mar 05, 2009
  • 132 Answers
SOURCE: washer stops at rinse cycle
Hi There,
Sounds like you need a new timer. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Replaced the lid switch on my top loading washer and it fills with water and it still wont start.
There are a couple things that could cause that
1) The water level switch,but if it filled to normal level and the water stopped that is pretty unlikely.
2) the motor,if it just sits there silent and no humming/buzzing noise the motor is most likely not the problem,if a heavy buzzing is heard the motor needs to be replaced.
3) again if it just sits there and wont make any sounds no matter where its set at,the timer is the very probable trouble.
I hope this helps you diagnose your washer trouble,
Gene
Aug 05, 2011 | Washing Machines
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Apr 13, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Maytag Performa Washer...It will fill with water but will not move through the cycles...it simply sits full of water and you can hear a humming noise and a smell possibly like rubber. A friend...
sounds like either you have a stuck pulley or pump remove water with shop vac and tilt washer against wall get under washer remove belt spin small pulley by hand does the pump pulley move all directions freely if not something stuck in pump or is belt melted or worn out
Jan 27, 2011 | Washing Machines
Just sits there and hums
the humming sound is coming from the solenoids on the water valve or the motor,also something could be stuck in the pump,does it fill with water?get back to me and let me know
Nov 29, 2010 | Roper RAX4233PQ Top Load Washer
Washer has water but doesnt spin frigidaire gl2940es
Something is stuck in the pump. Remove the hoses and remove the items. It will probably be a coin.
Jun 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
But will start with hot.kenmore 70 wont start with the cold water
Hi, First thing you want to do is start the cold sysle and listen for a faint hum. If there is a hum,turn supply valve off and remove fill hose.
Look inside the valve on the washer and see if something is plugging the screen. If the screen is plugged flush it out (do not remove the screen.
If the screen is not plugged, and there was no hum when washer was trying to fill with cold water, you will need to change the inlet mixer valve.
Please let me know if this has helped or if I can assisst you further.
Thanks
Vic
May 27, 2009 | Kenmore 22422 Top Load Washer
Washer stops at rinse cycle
Hi There,
Mar 30, 2009 | Maytag Washing Machines
Frigidaire gallery stack wash/dryer
Jul 28, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
WASHER HUMS HOWEVER WILL NOT FILL
water is frozen in your hoses. defrost hoses
Feb 09, 2007 | Kenmore 24722 Top Load Washer
Washing Machines Logo
198 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
