Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My six year old chainsaw won't start? - Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    New Friend:
If it ran before you stored it and you left gas in it, you can thank ethanol for your troubles.Try fresh mixed gas with a heavy does of ethanol treatment or Seafoam in the tank, prime it and try to start it 10 times, then let it soak for a few days and try again. Good luck
Posted on Apr 30, 2015
Florabest chainsaw fbks4614
The most common problem these days is old fuel. if the fuel is 2 or more months old dump it all out and start with fresh fuel.
Jul 27, 2013 | Garden
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
HOMELITE 4618C CHAINSAW WON'T RUN
How long has the chainsaw been sitting? How long has it been sitting with the same gas in it? Typically, most chainsaw and weedtrimmer repairs are fuel related. More times than not, simply draining the old gas, and putting brand new fresh mixed fuel just purchased from the gas station will fix most non start problems. Many people will not believe me, but after 20 years of fixing small engines, i've fixed 70% of the chain saw and string trimmer and related sized engines by putting in new fuel. Fuel goes bad now a days in 30 days. So if the fuel in the gas can sitting in the garage is older than 30 days it is old when you are considering trying to use it in a small engine. Fuel in a car will not cause the same issues as quickly for several reasons. If the fuel in the gas can is older than 30 days get rid of it. If after changing the fuel out completely doesn't fix your problem, feel free to contact me and I'll see if I can help you out.
Sep 02, 2012 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
3 month old Husqvarna 235. Refuled. Won't start. Plug is firing. Primer bulb gets full. Still won't start.
These machines have had issues with main bearing cages breaking up, this it turn scores the piston and snags the ring in, if there is a good spark and the plug is getting wet i woud whip the muffler off and take a look at the piston through the exhaust port.
Jun 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I was drilling into timber and my Drill started smoking i stoped using it and hoped it just needed to cool down, two weeks later i pulled the trigger and it started smoking straigt away can it be fixed it...
Check the brush tension springs to see if they have collapsed due to overheating. If the motor windings have crisped, then it's probably new drill time. Suggest buying a larger drill if you are heating this one in regular fashion. Good luck!
Aug 11, 2010 | Garden
Have an old Home Lite chainsaw not used since before I had it running when I had some woods to cut a long time ago. The chainsaw (over 25 years old) won''t start when I try....not sure if it just needs a...
Replace the fuel filter, fuel lines, primer button (if equipped), and disassemble the carburetor, clean, and re-kit. Jet needles are preset at 1-1/2 turns CCW from stops (lightly). Make sure the spark plug fires a snappy blue spark when pulled through. If nothing, ignition parts prices and availability may justify replacing the saw with a new one. If sparks ok, start the engine and let warm up. Open the throttle and adjust H needle CW till the engine speeds up, but still 4-strokes. Proper setting is when the engine will 4-stroke, but immediately 2-stroke when cutting. Let the engine idle and adjust L CW so that the engine idles fairly well, but allows the engine to 'follow the throttle' Hope this helps!
Apr 17, 2010 | Garden
Six year old Whirlpool 3357978 washer stops spinning violently
the bowden cable requires adjusting like the brakes on a push bike
Nov 17, 2009 | Washing Machines
Ryobi PCN 4040 will not start up
When I was going to college I worked at a tool rental center and learned may tricks about tools. At this rental center chainsaws were seasonal thus sat in the warehouse probably as in your situation. Well one is supposed to store a chainsaw without any fuel and discard any old fuel mix because it will not keep. To easily start a saw that was in storage we would install a new spark plug, add fresh fuel mix and spray carburetor cleaner directly into the carbureter to get it started. Once started fresh fuel would be drawn into the engine from the tank and keep running. If you forgot to drain the old fuel, do it now and use the trick above. For best results, always use a fresh plug. Enjoy
Dec 15, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
150 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
