Question about Timex E Tide Temperature Compass Watch T45601
I changed the battery and now it works but some of the number sections are gray and not black.
How do you change the battery in a reizen talking watch it is radio controlled white face with black numbers
  • Remove back
  • Find battery. Note mounting arrangement for later.
  • Identify battery type
  • Obtain replacement battery
  • Remove old battery
  • Install new battery with correct polarity
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will handle replacement.
Take TTTT
Dec 02, 2016 | Reizen Watches
Hi, my polar ft80 (black screen, white numbers), stops working quite often. The screen turns black and when it comes back, i have to go through the settings screens again. It happens about once or twice...
probably there's a problem with the connection of the battery of your watch, that's why it turns off, second it might have a different size of battery that have been installed. or the battery is not properly installed. these are all the possible cause of your watch. i hope i had been helped you.
Jul 22, 2011 | Polar FT80 Heart Rate Monitor Watch...
Where is the reset button in my timex chest strap
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
Feb 14, 2011 | Timex Ironman Race Trainer Digital Heart...
I change the battery of my nixon superhero TI/PU and now i cant see the digital numbers what can i do??
you need to restart digital part of the watch. Open it ( the screws part) and there you will find 2 reset contacts. You need toen close the contacts with the big battery in it. Then it should start working. This acion have helped me few hours ago.
Jun 19, 2010 | Nixon Super Hero Ss Ii Black Watch
How do I replace the lithium battery in a Casio Privia PX-100?
mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Jun 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need instruction manual for Timex 1440 sports watch. The manual on the website for the 1440 is not my watch.
I have this watch, it think its the same one, the manual on the website didnt work for me either :D
okay
To change the Alarm
Hold mode whilst on the time section.
then start/stop changes between hour and minute, adjust changes the number.
To get off that press mode again.
To change the actual Time
Go on to the stopwatch section Hold Mode, if it shows you the alarm press mode to change to time. The seconds should be flashing, press start/stop to change between hour minute second date, and adjust changed the number.
I really hope that helped even if its a month late :D
Sep 13, 2009 | Timex Watches
Day and date are black and red and the time is black over gray..i want all black over gray
The LCD display was manufactured with those colors (meant to be a convenience) and is not something that can be altered.
Jul 31, 2009 | Casio G Shock Mudman Black with Red...
Lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Jan 11, 2009 | Bulova Watch
Indiana (IU) Fossil Kaleidoscope watch
It has two batteries.  The 2nd one is not obvious.
Jun 10, 2007 | Fossil Sport Washington State University...
Timex E Tide Temperature Compass Watch T45601 Logo
27 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
