Question about Hoover Dryers
My tumble dryer keeps tripping the fuse book when I press start
    Master:
  • 456 Answers
There may be a loose wiring connection in the house wiring. Try using a heavy wire gage extension chord if it is gas, otherwise, go thru the dryer house circuit opening boxes and checking splices and connections. You'd brobably see char or discoloration of the wire insulation, if you do, you may be able to cut off the bad part and redo the connection, kill the power before doing this to avoid injury or other problems. I'd start at the circuit breaker panel, then at the receptacle outlet, then in between. If the dryer circuit has other items in it, then the circuit is being overloaded, run the dryer by itself.
Posted on Apr 03, 2015
When i press start it trips the electric on my tumble dryer
sounds like you have a short possibly the heating element .call a service man
Jan 30, 2015 | Dryers
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Hotpoint tcl770 condencer tumble dryer, just out of warantee. when turn on and start it keeps tripping the electrics. changed plug fuse etc, tried in various sockets but keeps tripping the system???
internal problem, either heater coil or sensor or motor, you will need to get it checked, but don't plug it in again, as short circuits on high current machines can be dangerous.
Jan 14, 2010 | Hotpoint Dryers
Kenmore heavy duty. its working properly but not heat
Power from the house:
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element:
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse:
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring : A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
thanks and keep updated.
Jul 08, 2009 | Kenmore Dryers
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
TUMBLE DRYER
Allybo check how the power cord is wired to the dryer. I have seen where the hot wire has been attached to the ground of the dryer and this will create a short which will trip the breaker.
Jan 28, 2008 | Dryers
Dryers Logo
74 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
