Question about Indesit KDP60SE Stainless Steel 60 cm Dual Fuel Freestanding Cooker 65 l l, B Energy Rating
Gas hob gets no gas
No gas flow
  • Indesit Master
  • 9,845 Answers
The pressure regulator is most likely the problem. It will be found in between the gas hook up point and the gas valve for each burner.
Posted on Apr 03, 2015
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
No gas coming out from all hobs
Do you have a drop down lid over the burners, if so the mechanism may be faulty. Most of this type of design has a safety cut off when the lid is shut, and it won't allow gas to flow through to the hob, lift the lid and check behind and see if it has stuck closed.
Apr 28, 2013 | Verona 34 in. CTG536S Gas Cooktop
Gas not reaching one hob. Have cleaned jet
if you cleared the hole and there is no gas comming out, then it is mostly a problem at the valve in under the knob.
the valve may have been frozen, or burned frozen, and you broke a small pices on the metal par( it stickes down to the valve top) and , when you turn the knob it turns the valve. that will have to replaced.
i think most places sell the whold valve pices about 50, easy to replace, if you get the top off.
Apr 16, 2013 | Cooktops
Stoves sterling 1100DF hob burners will not ignite there is no spark to any burner. Gas flows as normal.
More than likely the spark module has malfunctioned and needs to be replaced.
Apr 23, 2012 | Stoves Kitchen Ranges
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Oct 07, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
Gas doesn't come through to hob
hi,mostly is the problem is in only the line,i think ur line is far in ur cooktop thats why is the gas flow is slow to out in ur cooktop try & try,open ur gas valve for about 3 min or more until the gas is out.
Sep 03, 2009 | Whirlpool GLT3014 Gas Cooktop
SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Indesit KDP60SE Stainless Steel 60 cm Dual Fuel Freestanding Cooker 65 l l, B Energy Rating Logo
74 people viewed this question
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
Paul Carew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
