Question about Garden
What is spark plug gap and how can i set chain tension?
  • 85 Answers
Loosen the bolts on the side and then turn the small knob to set the chain tension.
Posted on Feb 22, 2016
  • 10865 Answers
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Posted on Feb 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: WHAT IS THE SPARK PLUG GAP!
.020 according to the site I just looked at.
Posted on Feb 16, 2009
  • 4088 Answers
SOURCE: I have a McCullough Mini Mac 6 chain saw. THe
0.020" is a good gap setting for magneto type ignitions. Champion is the original plug and they seem to work well. If the plug is clean, it should have a snappy, blue spark when observed out of the engine. Hope this helps!
Posted on Apr 09, 2010
Testimonial: "Thanks, That was very helpful for the gap setting, ignition type and diagnostic advice."
  • 4088 Answers
SOURCE: what is the gap on a spark plug for a 36cc craftsman chain saw
0.020" should work well. Good luck!
Posted on Jun 20, 2010
  • 3 Answers
SOURCE: What is the gap setting between the ignition
Unsure about your first question as I have had no problems with the ignition module or flywheel as of yet. However the spark plug gap is 0.025 inch
Posted on Oct 24, 2010
How do you remove a plug and chain?and then replace it with a new one?
I spark plug is removed by taking off the electrical push-on cord, taking a ratchet wrench with a socket that fits the spark plug, and then remove it. Replace it with a new one purchased at a hradware store, making sure you set the spark gap properly. On a chainsaw, the blade is removed by one or two nuts that must be loosened with a wrenck or ratchet wrench, which will alllow you to remove the chain, and then replace it with an identical chain, and reverse the process of taking it off. Make sure it does NOT get over tightened or undertightened. It should have about i/2 inch play above the saw blade when you pull the chain. Make sure the two nuts are tightened securely after adjusting the chain tension, and make sure the reservoir for the chain oil is full of oil.
Oct 14, 2014 | Garden
Air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
Mar 20, 2013 | Stihl Garden
Husqvarna 365 backfireing
Check your spark plug for 'whiskering' (tiny strands of carbon collecting across electrodes) and clean and re-gap. If this not the problem, check carburettor fixing to engine - may be drawing air through failed sealing gasket. Good luck!
Jun 09, 2012 | Husqvarna 362 365 371 372 385 570 575 576...
Red max eb7001 has new coil,gapped right still no spark. im going crazy
1) The primary circuit: is battery, cap, resistor, capacitor,switch ignition+secondary circuit spark plug, distributor, high tension wires+spark plug.
the mayor problem arise in the coil and distributor, And the most common problem INCORRECT Choice de spark plugs or improperly gapped.
Rememeber the coil send 20,000-30,000 Vdc for spark plug.
Test with a screwdriver , pull out the center wire from the distributor cap and hold 3/8inch from a good ground. Crack the engine, if there no spark, or the spark is weak, the coil is defective or the high tension wires.
2) Bypass by a moment the baas resistor with a jumper wire while cranking engine If the engine starts, replace the ballast resistor.
God bless you.
May 12, 2012 | Cars & Trucks
Chain saw died, no spark. replaced the magneto, still have no spark. gaped it with a .010 brass feeler gauge. disconnected the grounding wires. could it be possible to have 2 bad magnetos. Repalcement part...
Hi, gap should be 8 thou. Try this with a new plug. Check the magnets on the flywheel. It is possible to have a faulty new magneto but not that likely. Also check that the sparkplug terminal is contacting through the high tension lead correctly. Regards Phil.
May 16, 2011 | Ryobi Factory Reconditioned 18" 40cc...
Need to do a tune-up. what are the settings on the spark plug and on the magneto gap.
The plug gap is 0.020". Use a thin business card for the ignition module gaps--turn the flywheel so that the magnets are under the module poles, insert the card into the gaps, loosen the module screws, and allow the poles to contact the magnets. Tighten the screws, and turn the flywheel somewhat to release the card. Then turn the flywheel one full turn to make sure the gaps don't close further. With a fresh spark plug, the spark should be blue and snappy. Hope this helps!
Dec 09, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
What is the gap setting between the ignition module and the flywheel? What is the spark plug gap?
Oct 09, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas chainsaw has no strong spark and wont start
the air gap should be .012", the gap you have it set at is to small.reset the gap and try it again.......hope this helps,let me know........
Jun 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Spark plug gap
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
